New owner of '07 Air Nautique 236, and have 2 questions:
1. the lean back seat uprights are both jammed in - I'm assuming they're intended to be pulled out if you want? Before I get to heavy handed with them though, thought I should check to see if they're actually intended to come out.
2. The plastic gauge face on the 3 factory ballast gauges are cloudy and make it hard to read the position of the needle - is it possible to polish these plastic faces or otherwise restore their clarity?
Thanks so much for any help.
