what octane fuel does the Excalibur require? What about teh ZR6?
fuel reccomendations
I believe the Excalibur preferers 87 octane, and the ZR-6 wants 89 octane. The computer on either engine will adjust for a lower octane gas, if the higher is not available. There is no advantage in running a higher octane, and you will lose power. If your boat is sitting over the winter, use a fuel stablizer, also. PCM recomends Sta-Bil.
RE: fuel reccomendations
All PCM engines since the change to GM in 2002 are calibrated for 87 octane. Pro Sport, Excalibur, and ZR6. There was a sticker on the early Excaliburs that stated that it needed 89, but the sticker is incorrect, according to PCM.Please do not PM me directly asking for advice on how to repair your boat. While I would love to help everyone, I simply do not have time to respond to all of the inquiries. Please post your questions on the forum, so that all of our members have a chance to answer.
Re: fuel reccomendations
thanks. i know octane requirements are directly related to compression ratios, and i always laugh at slugs whom use a higher than recommended octane...they are just throwing money away. anyhow, i did not know if the ZR6 was a high compression engine...Originally posted by DanielCI believe the Excalibur preferers 87 octane, and the ZR-6 wants 89 octane. The computer on either engine will adjust for a lower octane gas, if the higher is not available. There is no advantage in running a higher octane, and you will lose power. If your boat is sitting over the winter, use a fuel stablizer, also. PCM recomends Sta-Bil.
