Spare Prop
I have a 1995 Ski Nautique, 351 EFI Ford GT 40, 310 HP, PCM 1.23: Trans.,
The local lake I visit is at 7500 ' elevation. Some lake use at 5000' here in Colorado. And some trips to Lake Powel. Currently I have plenty of hole shot, I would like a little more top end.
When in reverse the rear of the boat moves to the left and I cannot counter steer to over come the direction, another words trying to back up to the right is impossible, (though lack of experience is part of it, but I think the prop rotation is a lot of it). If seem some posts on the back up issue, and will just have to get use to that. I have heard that 4 blade props are smoother and produce less wake, but require more horsepower to be effective. I would like to consider a 4 blade prop if it would work with my boat that would be similar to the current results I get with my existing 3 blade 14x16 x 1 R (I think it is a 1" shaft, Right rotation) prop but with just a bit more top end (a few more MPH at same recommended sustained WOT. I do not know if 3 or 4 blades would help the reverse operation.
Any insight or recommendations would be great. Thanks
