I found myself getting frustrated with the transom remote buttons getting pushed accidentally on a number of occasions (2018 G23). The most annoying occurrence is when the source button gets accidentally pushed and I (the driver) has to switch screens to set the source back to where it needs to be.
I've had these accidental button pushes occur in a few different scenarios:
The solution is a guard designed to protect the buttons from accidental bumps, while still allowing the buttons to be pushed intentionally to maintain function of the remote. This Button Guard replaces the original trim ring and simply snaps into its place.
The Button Guard is currently available in texturized Carbon Fiber Reinforced PET (chosen for strength, UV resistance, moisture/humidity resistance), and work is underway on releasing a clear anodized aluminum version in the near future as well. There will be a 15% off promotion with discount code PN15Off running until the end of August for Planet Nautique members. This link automatically applies the discount code: https://www.evokemfg.com/discount/PN...autique-models
Given that the design is fairly new, I've created an Early Adopter Program for the Carbon Fiber Reinforced PET version which is kinda like warranty, but better. How it works - if there is any sort of failure of the part, it will be replaced at the cost of shipping upon reporting information about the failure. Replacement isn't conditional on how it failed, but rather to drive design improvements if needed. (There have been zero failures to date.) Additionally, if a design change is made in the future, an Early Adopter can upgrade their Button Guard to the new design for the price of shipping and the difference in cost (if there is any). This upgrade process will be available for the future aluminum version as well!
Follow the Evoke MFG Facebook page for updates to design and aluminum version availability: https://www.facebook.com/EvokeMFG
There is a poll at the bottom of the post - I look forward to hearing your feedback!
I've had these accidental button pushes occur in a few different scenarios:- A new surfer is finding the pocket for the first time with a slack rope in hand, and it swings against the remote and pushes a button.
- A rider/surfer tosses the rope into the boat, and the handle or part of the rope bumps a button in the process.
- When floating/swimming, someone brushes against the remote when they sit nearby. I find this is most likely to happen when there is a large crew, and everyone is crowded around the swim platform, and someone sits in the walkway or on the cushion and bumps the remote with their leg.
