How hard do you try to center your boat on the trailer? I have a 2000 SAN and a DHM trailer with vertical roller guides on each side. When I drive on the trailer, there is a 3-4" gap between the boat's rail and each guide. When we pull the boat out of the water, it is really hard to keep the boat centered between the guides and the boat usually winds up sitting off center with the side of the hull right next to the inside edge of the trailer fender.
The side guides are welded to the frame or I'd try to wedge them up so there is less gap between them and the boat. Any other ideas?
Thanks - Gene
Thanks - Gene
