Originally posted by JACOB11379
View Post
Happy to help! Will answer what I can and/or provide my thoughts, but reach out if you have other questions.
Top speed - sounds about right, but other than break-in never go that fast. There is a video (perhaps what you saw) where N3 got a Paragon up to around 42ish, but that was with different motor/v-drive and also a much different prop (the old G23 stock prop 3561).
Engine code - was it during the full speed pull? I've never seen that type of code before, and only thing I can think of is RPMs somehow exceeded max during high speed. You could ask them about it as still should be stored in fault log.
Subwoofers - definitely something not set right. Were you connected via bluetooth or cable? Stupid question, but are you sure volume was all the way up on phone? We have usually listen to music between 24 and 36...36 for the towers when someone is riding, and the tower and rear subs are LOUD at that setting.
Steering assist - I have had that happen a few times if am very close to 4mph, but is really rare. I assumed speed was just too close to max and there's a bit of buffer there before it engages. I do know if you do too much back/forth with it that it will disable temporarily, but have never had that happen to me. As for the close to 4mph thing, I use paddlewheel on everything except wakeboarding with full ballast and that seems to help with keeping the thrusters ready to engage in auto or manual always.
Tsunami stops - yeah, all have been there and done that! The G23s and Paragons sit deep and slow pretty fast with their massive props...so just invites that rooster tail to catch the boat and come on inside. That said, yes it is something you quickly get used to and easily prevent from happening. Hard to describe on internet, but when I go to stop I just let off throttle then turn left a bit, right before water hits back I blip the throttle and that is just enough to have water hit rear corner rather than walk through. Side benefit, it turns the boat around that much quicker and makes getting back to rider quickly easier.
Ballast - yes, that is the downside to having 2200 lbs all sub-floor....they use reversible pumps that can only go so fast. I do think that they use larger pumps than in the GS series, but again you're filling 2200 lbs which takes some time. I have my routine down now such that I never notice it...get to ride spot, start ballast, raise tower (rolling out stealth mode is a must), situate passengers, get gear ready and stretch a bit, on back deck and jumping in just about the time it is full.
Sac river - they probably should have told you, but that was only choice. Folsom has been shut down to only 5mph on the whole lake.
Good luck!
