Good advice so far, another trick to get the board under you is have the driver put the boat in gear and idle, giving you slight pull from the rope. Hold on with your front hand and reach between your legs with your other hand and flip the board up, where you feet are flat on it. Now grab the handle with both hands and have the driver slowly pull you up. Following the above advice on being low in a ball.
The Kong should be plenty of surf board for you.
