2019 G improvements — ones I didn’t know about or weren’t
  • nyryan2001
    • Mar 2013
    • 1993
    • Lake Anna
    #46
    Every G I’ve had has the same problem.
    look at where your bimini folds... and touches and rubs on the other parts of the bimini. It’ll eventually wear through if you keep it folded and do a lot of towing.
    .99cent sliced pool noodle to insulate those areas
    2019 G23 450
    2014 G23 550
    2013 G23 450
    2011 Malibu Wakesetter 247
    2007 Yamaha AR210
    • Tallredrider
      • Oct 2014
      • 1026
      • St. George, Utah
      #47
      I think it might depend on what you mean by a lot of towing. My last G I had for 3 seasons and towed about 700- 1000 miles per year. No problems. IIRC, NYRyan tows way more than that. I did not see any evidence of the bimini 'wings' shuddering against one another.
      • XBIGPUN66
        • Oct 2012
        • 477
        • Lake Mendota
        • WI
        #48
        On my 210, if you have the bimini top cover sleeve on correctly it is not a problem.
        Ian S
        2014 SANTE Reef Blue/ Black metal flake. NSS. Pro balllast. Boatmate trailer
        2004 SANTE Masters Blue. 4000 lb ballast, 2013 graphics (prev). Ramlin trailer
        2009 Moomba Outback Red(prev). Boatmate trailer
        • nyryan2001
          • Mar 2013
          • 1993
          • Lake Anna
          #49
          My first G scissored through the material before I figured out what was happening. Was covered under warranty.
          my 2nd G I noodle shimmed 90% of the time, still had wear marks for the few times I didn’t shim.
          this new one already has marks already just from the tow home. In the surf board pads.
          guaranteed there’s wear marks... to whatever degree in your Biminis if you did any decent towing. If your boat lives on a lift it’s probably not a problem.
          2019 G23 450
          2014 G23 550
          2013 G23 450
          2007 Yamaha AR210
          • blueroom
            • Mar 2017
            • 626
            • Northwest
            • G23
            #50
            We tow 2000-3000 miles a season on highways. 3 seasons and no Bimini issues. Do you use the up/over/under method with your cover to get things tight? You can’t just slide the cover on and fasten the loops.
            • XBIGPUN66
              • Oct 2012
              • 477
              • Lake Mendota
              • WI
              #51
              Yes we use the up under over method when towing on trailer. Otherwise in water it is just buckled behind the tower bar.
              Ian S
              • tchancey
                • Mar 2014
                • 14
                • Colorado
                • 2016 G21
                #52
                What is this up, under, over method of which you speak? I recently bought a 2016 G21 & have been blissfully unaware of anything special I needed to be doing.
                • Evening Shade
                  • Apr 2015
                  • 1295
                  #53
                  I would like to know as well. I just put the bimini cover on the same way Adam Winsink shows it done in the walk through videos.
                  • XBIGPUN66
                    • Oct 2012
                    • 477
                    • Lake Mendota
                    • WI
                    #54
                    I will take a pic tomorrow and post
                    Ian S
                    • nyryan2001
                      • Mar 2013
                      • 1993
                      • Lake Anna
                      #55
                      Towed approx 900 miles this week with tower down... ended up with small rips in the top of the bimini boot. Had the slide in Air dam in place.
                      2019 G23 450
                      2014 G23 550
                      2013 G23 450
                      2007 Yamaha AR210
                      • XBIGPUN66
                        • Oct 2012
                        • 477
                        • Lake Mendota
                        • WI
                        #56
                        Her are the pics of the up and under method
                        Ian S
                        • nyryan2001
                          • Mar 2013
                          • 1993
                          • Lake Anna
                          #57
                          I fully understand what you’re doing there...but it has nothing to do or ability to stop the 2 side wings of the Bimini from rubbing on each other when folded and scissoring the material.
                          2019 G23 450
                          2014 G23 550
                          2013 G23 450
                          2007 Yamaha AR210
                          • tchancey
                            • Mar 2014
                            • 14
                            • Colorado
                            • 2016 G21
                            #58
                            Here are the pics of the up and under method...
                            Thanks!
                            • Gschofield62
                              • Mar 2019
                              • 105
                              • Regina beach, Saskatchewan
                              • 2020 G23
                              #59
                              Originally posted by sixcampbells View Post
                              Great write up! Totally agree on the Klingon �dead lift� board racks. The concept is great but the execution is lacking for the majority of my family who struggle to balance up on the side wall and lift the arm to clear the board.
                              I'm glad I'm not the only one who thinks these board straps are seriously difficult to pull up from the position they are in. We have resorted to bringing the racks inside the boat and having two people reef on them. I'm a fairly big strong guy and these things challenge my manliness daily.
                              Sent from my SM-G955W using Tapatalk
