Gas cap replacement
  • igkya
    • Oct 2003
    • 229
    • Minden, NV
    • Club boat 2005 196
    Gas cap replacement
    The gas cap fell off while fueling. The screw that connects the cap to the chain fell off, no one noticed this until it was time to put the cap back on.... ooops, no cap, it's at the bottom of the lake. No problem to replace, just curious on others thoughts if this should be covered by warranty?
  • surroundsound64
    • Jul 2005
    • 2148
    • Longview, TX
    • 2026 S23 1981 Ski Nautique
    RE: Gas cap replacement
    Are you serious? You dropped the cap, why would this be under warranty? I'm pretty sure the dealer would laugh.
    Sorry, I hope for you the best, but I don't think it'll happen.
    2018 SAN 230
    1981 Ski Nautique
    Sold - 2011 Sport 200V
    Sold - 2000 SAN
    • DavidF
      • Sep 2004
      • 611
      • Austin, TX
      I think since the retaining chain either broke or came loose from the cap, then yes it should be covered under warranty if the warranty is still active. The chain is there to so this situation is avoided. Yes, make a warranty claim.
        • 2909
        • Current 2017 GS22
        There is no way to make these boats completely foolproof. If it was within the first 20 hours maybe under warranty or a courtesy replacement from the dealer to keep a happy customer. If it was after 20 hours... just buy a new cap and get back to enjoying the boat. The cost of the cap is probably less than the cost of towing the boat to the dealer.
        • ag4ever
          • 1180
          My chain is not connected to one of the fuel caps. I guess I should reattach it soon so i don't have the same problem. Mine happened the first year we owned it, anf I guess I just have not been that concerned. I am really carefull when fueling on the water as to not loose the cap.
          Do you know what size the screw is that attaches the chain?
          • igkya
            • Oct 2003
            • 229
            • Minden, NV
            Well, my dealer has sent me the wrong gas cap twice now. The 1st one screwed into the hole, but was too big to set flush. At least it made a tight seal. The 2nd one was way too small. Both times I told them the year and model boat. How many different gas caps did CC make?
            BTW, does this sound like Goldylocks & the 3 bears... too big, too small, just right (I'm hoping).
            • darrel409
              • Jul 2004
              • 566
              • San Dimas, So. Cal
              Had the same thing happen on my 93Sn. Couldnt get the right replacememnt cap, spent a summer using a very attractive threaded pvc cap. Eventually ended up replacing the whole filler neck piece. My current boat has a cable instead of the unreliable chain.
              • pschne1
                • Oct 2003
                • 25
                I run a camp that has 6 2006 nautiques (4 206s and 2 210s), and we have lost 3 caps already. the problem is that the cap hangs at the same height as the rub rail, so when the boat pushes into the dock it pops off the cap. we sent someone down by our fuel dock, and he came up with seven gas caps. the chain should either be shorter, or longer to avoid the problem. the piece that holds the cap to the chain is a joke.
                • wakejunky
                  • 679
                  • Ca
                  • 2003 SAN
                  I have a chain at the bottom of my tank. I wish there was a better option for the cap because you never know when the screw has come loose and you open up the cap to find that it's either in your hand or on the ground/bottom of the lake.
                  Chris
