G21 motor
  • DocPhil
    • Jan 2016
    • 478
    • Midwest
    • 2016 G23; yamaha superjet
    G21 motor
    We are looking at a 2014 G21. It has the 5.7L 343 HP PCM. Dealer says it does fine surfing. Needs some help fully loaded wakeboarding but we only surfs.
    Is this correct?
  • vanhanbr
    • Mar 2014
    • 223
    • Wisconsin
    • 2008 SAN 210
    Sound like a terrible setup.
    2008 SAN 210
    1997 Sport Nautique
    • Infinity
      • Sep 2017
      • 730
      • Lake Norman - Denver, NC
      • 2014 SV244 w/ ZR409
      What is the elevation, that can play a role in power? Key of course it to load it up with ballast and people and demo to be sure it will be good...but that motor should do ok on that size boat if not a high elevation and you can always get a surf prop to give it more low end torque, if all he does is surf then low end is all that will matter. Lots of 21/22ft boats have that engine.
      • vanhanbr
        • Mar 2014
        • 223
        • Wisconsin
        • 2008 SAN 210
        True, but my 210 weighs 1700 lbs less than a g21.
        2008 SAN 210
        1997 Sport Nautique
        • DocPhil
          • Jan 2016
          • 478
          • Midwest
          Right but the G also has a 2:1 tranny and 17 inch prop.
          • nyryan2001
            • Mar 2013
            • 1993
            • Lake Anna
            What's the price? 70-80k?
            2019 G23 450
            2014 G23 550
            2013 G23 450
            2011 Malibu Wakesetter 247
            2007 Yamaha AR210
            • scottb7
              • Aug 2011
              • 2198
              • Carson City, Nevada
              I have the 409 and highly recommend it. However, I would say that when the g21 first came out i would not - and probably - would still not want the 343. But, before they don't - but today they do have other propellers that could give more power - and of course lower top end speed, that would make it work just fine.
              So yah, it will work - and ncrs helps a lot - but you will need to re-prop is my personal opinion.
              • DocPhil
                • Jan 2016
                • 478
                • Midwest
                That is good feedback. Thank you. It is interesting to look at the torque curves. The 343 actually out torques the 409 until 3000 RPM. Scott, what are your RPMs at surf speed, wakeboarding speed and what is your top speed? this will help on the demo.
                • xxrb2010
                  • Jan 2014
                  • 226
                  • nc
                  From what I hear, G21 with H5 is ok G21 with the former 343 is not ok. I do have a G21 with H5 and it is ok, but my boat is never fully loaded with a large crew, only ballasts are fully loaded .
                  If you like to have your boat coming to speed in a half second time frame with full ballast and 12 people crew, forget the base engine.
                  • xrichard
                    • Aug 2008
                    • 671
                    • El Dorado Hills
                    • 2023 G23
                    The 409 doesn't outperform the 343 until higher rpms. Bottom line, at lower elevations the 343 will do fine with full ballast at both surfing and wakeboarding speeds and 3-5 people. At higher elevations or riding with more people in the boat and you might want the larger motor particularly for wakeboarding. However, the best advice is to load it up and try it out. Outside of that, there's a resale issue because many think the 343 is under powered.
                    I can offer one data point: I ran my 2008 210 with 343 at 450'-1200' elevation regularly with 3000 lbs total ballast, typically four people in the boat. It was slow out of the hole....typically 20-25 seconds to 23 mph...but held speed no problem. Getting on plane was more difficult if I had a lot of weight in the rear and as I got to higher elevation. I don't think that will be much different 343 vs 409 given their similar torque curves under 3500 rpm. In any event, that boat weighed 3800lbs (per the factory, IIRC) for a total weight with ballast of 6800 lbs.
                    The 2014 G21 weighs 5200lbs (per the factory) for a total weight of 8050 lbs with stock ballast. You're pushing 1250 lbs more weight, but you have a 2:1 tranny, a larger prop, and NCRS (which is a big deal wrt getting up to speed). FWIW, the prop on my 210 slipped quite a bit under load, effectively reducing usable power and the hydrogate was nothing comparted to NCRS for getting the boat out of the hole.
                    I corresponded with Jeff on this exact issue back in 2014 when I was thinking of buying a G21. I just reviewed that exchange. He said on his press visit in Florida that the 343 had no problem pulling pros (wakeboarding) with a boat load of media and a short setup to get to speed. He thought there'd be no issue for my application, which I described as wakeboarding with full ballast, 5-6 people. I also started a thread on PN....I'm sure if you search you'll find it. It would have been October 2014. I can't remember if there was good input there or not.
                    Previous boats:
                    2015 G23
                    2008 SAN 210
                    2002 XStar
                    1995 Sport Nautique
                    • DocPhil
                      • Jan 2016
                      • 478
                      • Midwest
                      This is awesome feedback and yes I did review that thread. This is pretty much what I expected. Most people assume that the 343 won't get it done but under 3500 RPM there is no difference between the motors and in fact the 343 might have a slight edge. Resale is a good point. That might be affected. However, we are getting such a smoking deal on this boat that it is hard to turn down.
                      • mlsurfco
                        • Oct 2015
                        • 191
                        • Minnesota
                        • 2017 G23
                        Put 150 hours on a 15 G21 with 343 last summer. NEVER had an issue with power while surfing, even with a few hundred extra of lead and large crews.
                        It was a problem at resale time as someone has spread the idea that it is underpowered.
                        • DocPhil
                          • Jan 2016
                          • 478
                          • Midwest
                          That is awesome to hear from someone with actual experience with the motor. Do you know what your RPMs were at surf and wakeboarding speeds and what you topped out at? Also what was your surf setup?
                          • Sailfun
                            • Dec 2016
                            • 131
                            • Lake Norman NC
                            • 2018 Nautique G23 2022 Robalo 226
                            I think the 343 will work if the price is right. Keep in mind however that people saying the torque is the same under 3500 are not paying attention to where the RPM is under loaded acceleration. The boat is almost certainly pulling 4500 plus RPM in the critical stage coming out of hole where you need the power.
                            • xxrb2010
                              • Jan 2014
                              • 226
                              • nc
                              Interesting: how the price has any impact on the motor? The less you pay the better the engine would be
