13 G23 additional ballast
  • blufly
    • Jan 2017
    • 78
    • new zealand
    • 13 G23 450 - 22 G23 ZZ8
    hi guys just bought a 2013 G23 with a 450 and looking for best additional ballast set up?
    my thoughts are the wake maker twin 1000's for rear lockers will be good for surf but will I need a bow bag to level boat out for wake?
    Goin to run seperate pumps for all new ballast but can anyone recomend best fitting bow set up
  • Kporsch
    • May 2013
    • 121
    • Houston
    • 2018 G23
    I had custom bag made from fly high that go from the rear lockers up and partially under the seats. I run pop bags in the bow. Pics of my pump install are under another thread.
    • Kporsch
      • May 2013
      • 121
      • Houston
      • 2018 G23
      G25 extra ballast
      https://www.planetnautique.com/vb5/s...d.php?t=508954
      Here ya go...
      • Wake.BC
        • Jan 2016
        • 423
        • BC, Canada
        Wakemakers has the G series bags on sale for 299 right now regular 450 ish.
        • blufly
          • Jan 2017
          • 78
          • new zealand
          great thanks guys ... Think I'm gunna roll with the 1000's in the rear lockers running on aux switches and pumps for speed. then a mobile 650 8.3 bag and pump in the bow want to keep lockers free for boat ****, anchor ropes bumps etc also ordered a 2315 this all should give me the options and flexibility I'm after
          Im new to PN and I've gathered some awesome intel from reading thru all the posts so THANX again all
          • Kporsch
            • May 2013
            • 121
            • Houston
            • 2018 G23
            1000's in the rear will probably be too much rear weight even for surfing on a 13. You may have trouble getting up to surf speed. Part of the reason I had custom bags made that distribute the weight forward partially under the seats.
            • blufly
              • Jan 2017
              • 78
              • new zealand
              Yo kporsch that link to your setup won't connect an I couldn't find through search. You got any dimensions of the bags you had made?
              • nohlan_4
                • Jan 2016
                • 420
                • Canada
                • 2013 G23 450
                1000's will be way to heavy if you plan on running with full factory ballast. A maxed out 2013 can run full factory and then one 1100 cheated to the surf side for best results. Anything more and you won't have the power to get up to speed.
                • blufly
                  • Jan 2017
                  • 78
                  • new zealand
                  Yo Nohlan did you end up traden out your 1100's for the 750's did this help
                  are you running the acme 2315 prop?
                  • nohlan_4
                    • Jan 2016
                    • 420
                    • Canada
                    • 2013 G23 450
                    I am trying to trade them out now. I have a maybe deal for some 650's right now but I really want 750's. I am running a ACME 2315 yes that is correct.
