Looking to add a depth sounder, any recommendations (in hull, transducer, thru hull)?
  • J10
    • Jan 2014
    • 66
    • Toledo, Ohio
    • 1996 Nautique Super Sport
    Hoping someone has posted a install to help me. Any info would be great
  • s_kelley2000
    • 1595
    • Fort Meadow Recevoir
    • Mass
    Do you also want Air/Water temp on the same gauge? If so I would go with this:
    http://www.overtons.com/modperl/prod...1scaAi4v8P8HAQ
    If you don't need the temps then I'd go with this:
    http://www.overtons.com/modperl/prod...bKgaAjjn8P8HAQ
    My boat has the factory installed Hummingbird depth gauge with in hull tranducer. In Hull is an easier install since you don't have to drill a hole through the transom. But once you get over the fear of drilling it's really no more difficult. If you want water temp you will need to go with the through hull.
    Shawn
    2012 Blue Metal Flake SAN 230
    • CBM
      • Oct 2015
      • 25
      • Morgan Hill Ca
      I installed a faria in hull depth finder. Very easy to do and I am happy with it.
      • SkiLogan
        • Jun 2016
        • 1
        • Huntsville, AL
        • 2008 Ski Nautique 196 SE
        Does anyone know if you can replace the paddle wheel with the thru-hull transducer? I have ZO, so no real need for the paddle wheel. I'm looking for one that has air/water temp as well. The link above is transom mount only for the one with air/water temp.
        If such a thing exists, it would be cool to find a paddle wheel with depth air/water temp all in one.
        • gunkyl8957
          • Mar 2016
          • 11
          • Menomonie, WI
          • Purchased 1999 pro air as our first Nautique
          Agree, I like the one above but I want a through hull transducer, does anyone have a link?
          • scottb7
            • Aug 2011
            • 2198
            • Carson City, Nevada
            see attached for some options...you may have to contact faria to figure out how to wire...
