Engine Overheated!
  • ncc74
    • Mar 2006
    • 3
    Engine Overheated!
    I lake tested a '94 SN today w/ the 310 h.p. EFI pcm pro boss that I'm interested in buying. While at about 3/4 throttle the engine started making a popping noise and noticed the engine was at 230 degrees. After shutting down the engine, we noticed the water intake line was left disconnected after winterizing and not hooked back up. The engine had no water getting to it at all. Needless to say, the impeller was melted away to nothing, because it was still overheating after reconnecting the water line. I need some advice. Should I steer clear from this boat now due to potential engine damage or are these engines equipped with emergency shutoff devices due to severe overheating? Any replies are appreciated.
  • krs0394
    • Jan 2006
    • 170
    • Sturgis, MI
    RE: Engine Overheated!
    Did you have water coming up in the bottom of the boat??? Water should have been rushing in going 30 mph. Also, at 230 degrees the little red light on the dash and the alarm should have been going off. I would steer clear of this one. Sounds like it has issues.
    1973 CC Skier
    1989 SN 2001
    2002 SN 196
    2005 216 Limited
    • surroundsound64
      • Jul 2005
      • 2147
      • Longview, TX
      • 2018 230 1981 Ski Nautique
      Back away and find another one. If this happened, theres a good chance other stuff have been missed in the past as well. Such as engine oil and what not.
      2018 SAN 230
      1981 Ski Nautique
      Sold - 2011 Sport 200V
      Sold - 2000 SAN
      • Hydrofoilmaniac
        • Apr 2006
        • 105
        • Menomonie, WI
        I agree with Larry. It's probably a good thing that it happened. The incident probably saved you some heartburn down the road. I use enough Rolaids with things that I know. I don't need to add to it with stuff like that.
        1976 Ski Nautique.....old but it\'s still going strong
        • EarlyRiser
          • 171
          • United States of America
          I wonder if this is what happened to "therev1"? [sorry to bring up the subject ] ER
