Closed valves and didn't leak down. Also started getting crazy w speed so stock full 750s full and bow bag at about 300 to 400 lbs and speed up to 12. Wave is crazy fun on skimer.
Wait. So you guys are closing the through hull valves that feed the pumps??? If so, that must mean the added pressure from the additional water weight is forcing it's way out right?
Pretty much. I was just topping off every hour or so but yesterday I closed valves after filling and they stayed full all day.Originally posted by markj View PostWait. So you guys are closing the through hull valves that feed the pumps??? If so, that must mean the added pressure from the additional water weight is forcing it's way out right?
Try without the headache of the bow bag and speed up a little more... we do 12.8 and it makes a sick long wave! We also run port completely full and stbd about 3/4....makes for a perfect wave on both sides.Originally posted by Neverenough View PostClosed valves and didn't leak down. Also started getting crazy w speed so stock full 750s full and bow bag at about 300 to 400 lbs and speed up to 12. Wave is crazy fun on skimer."I'm on a boat........"
