I am kicking around the idea of adding a little extra ballast in our G23. I have two questions that I can't seem to find an answer for:
1. I know the factory is soft bags. Do the vent lines on these have check valves? Or are they open?
2. I have not had a chance to pull anything apart and the boat is not here currently. How are the vent lines for the two rear and front tanks routed? It leaves the tank and goes to the thru-hull, but I'm not sure where they run the hose between the two.
