need help with tower paint problem
  • dskier
    • 100
    • ohio
    • 2012 air/sport 200V 1999 ski nautique
    I have a 2012 200V with a black tower. When traveling a significant distance, I used wrap the tower in pallet wrap to prevent bugs and such from messing up the tower paint finish. In the past year It was suggested to me to use painters tape as it has low tack and much less of a mess to put on and take off. Sounded like a great idea to me........ After returning from the weekend last night. I went to remove the painters tape and some little spots of the tower paint came off. The tower has plenty of wax on it to give another barrior. The tape was only on for a max of 2hrs. this time. It has worked great up until this point, not sure why or how the tape would pull off powder coated paint but I NEED to get it fixed! Any suggestions? Will post pictures later as I am now at work......
  • dskier
    • 100
    • ohio
    Here are the pictures. I am just not sure why or how this paint pulled off?? I could see if I had used a very tacky tape like duct tape or something.
    Any suggestions on touching the paint up? Any chance there was some sort of powder coating issue back then that someone knows about. Very puzzled!!
    • Nautiquehunter
      • Jun 2008
      • 2096
      Isn't it still under warranty? If the powder coat was done correctly no way should that have happened.
      • nyryan2001
        • Mar 2013
        • 1993
        • Lake Anna
        I can tell you for certain the 2013-2014 shiney towers aren't powder coat, they are enamel paint.
        lools similar to the rack issues with paint in the other thread.
        2019 G23 450
        2014 G23 550
        2013 G23 450
        2011 Malibu Wakesetter 247
        2007 Yamaha AR210
        • jward
          • Feb 2008
          • 620
          • Sweet Home Alabama
          • 03 SANTE 04 SANTE
          I would just tape it off, scuff it a little and spray with a rattle can. If you can find a paint that is a close match, I'm willing to bet it will be hard to find where it peeled off. That may be a temporary fix to a bigger problem though.
          • dskier
            • 100
            • ohio
            great.......so do I go to the closest dealer to start this process? or contact Nautique directly? never had a warranty issue with my "95"
            • 81nautique
              • Feb 2006
              • 257
              • Big Rock, Illinois
              • 2012 200 Sport 1956 Correct Craft Collegian Past boats 1955 Correct Craft Hurricane 81 Anniversary Nautique 1960 GlassCraft Ski Nautique #1
              Dealer is your first stop. That HAS to be a prep issue. Problem is to fix that correctly that's a big time consuming deal. I would try to get your dealer and Nautiques to warranty the repair and then have it done over the winter. Most dealers don't have the time to deal with that now and you certainly don't want to lose your boat now that summers here.
              They changed the finish to a textured one after my 2012, not sure if it's actually more durable but I'm sure this had something to do with the change. I have a bunch of chips from stones kicked up while trailering plus my Z5 brackets slipped down on my tower while towing once and really made a mess of the paint. I'm going to remove the tower when we put the boat away this year and get it resprayed over the winter.
              • dskier
                • 100
                • ohio
                Thanks for all the input! I will go talk to the dealer and see what they have to say. We cant be the only ones with this issue.......
