Well the boat I just picked up never had the ZO upgrade done so I get some nasty inconsistencies when taking a pull. Quite frankly I can't even believe this was installed from the factory with the performance you get. After 15hrs worth it's killing the fun. I can drive by hand better than this thing pulls. Zero off seems to have very limited adjustments to dial their syatem in and navigating through all the menus is far from easy. I am fluctuating over mph each way loaded up, it also takes forever to plane will surfing. We have been just disengaging it every fall and then pushing it on as boat get to speed surfing. It's really annoying. Those familiar with pp and the kdw(pull) adjustment does ZO have anything close to that? I have talked with zero off and they say the upgrade will fix it, but I am not buying it. There is next to zero fine tubing in wakeboard mode. I can't even get it to swap to rpm mode.
I know there is the antenna and software upgrade for the Zero off but the price on the antenna and harness is around 560 these days not to mention the labor with the software upgrade. For 900 I can get PP stargazer with way more adjustments and tweaking. Just wondering how big of a project this will turn into with eliminating ZO and Installing SG. If anyone has some thoughts fire away.
