1999 Pro Air - Combing pad removal
  • a0128
    • Jan 2014
    • 423
    • Lake Oswego, OR US
    • 1999 Pro Air Nautique
    I need to remove my combing pads on my '99 Pro Air in order to replace the speakers. Anyone done this? I've poked around a little but didn't see any obvious fasteners, clips, etc. Any guidance is greatly appreciated.
  • vortech347
    • Mar 2004
    • 95
    • Central Texas
    • 99 Sport Nautique - GT40 - FCT2 tower
    You shouldn't have to remove the pads to get to the speakers. They should be screwed in from the back into the pvc rings.
    I have a 99 Sport and I replaced the speakers several years ago and that's all I had to do.
    Once you remove the speakers you can then take the screw out that holds in the mounting rings to replace the felt speaker covers.
    I have not removed my combing pads but they are basically bolted to the gunnels from the back side.
    • shag
      • 2217
      They might use the 'christmas tree' fasteners like what holds on some car interior door panels. They are plastic, fit into the panel then are pushed into the mounting surface.
        I believe 1999 coming pads are bolted. There is a bolt, that goes through the backing, to the outside of the boat. that goes througha hole in the gunnel. Then a fender washer, and a 1/4 nut. If the boat was made right, thay put some silicone seal (RTV) on the bolt and nut to prevent vibration from loosening the nut.
        • vortech347
          • Mar 2004
          • 95
          • Central Texas
          That is how my 99 Sport is done.
          • s_kelley2000
            • 1595
            • Fort Meadow Recevoir
            • Mass
            As others have said they are bolted. This is from a Super Sport but this should give you a decent idea of what you are dealing with.
ID:	368481Click image for larger version
            Shawn
            2012 Blue Metal Flake SAN 230
