2014
  • s_kelley2000
    • 1595
    • Fort Meadow Recevoir
    • Mass
    #46
    The hull side is definitely a little Malibu-ish but I like the clean graphics. Maybe they will still offer the Griffin and Shield graphics like they offer the Progressive and standard graphics on the 200. The colored deck is definitely a cool option that I am glad they finally brought back. The new Graphite Grey, Reef Blue and Green Metal Flake colors look great. The pics of the Reef Blue G23 I saw floating around looks awesome. I’m not as sure about the Voltaic Yellow or Purple Metal Flake but I am sure some people will like them.
    As others have said it is very disappointing that they got rid of the reversible back seat but the transom walkthrough on the 210 is a nice touch that I have wanted to see for a while. Plug N Play ballast is another good new option but if I was ordering new I would probably plumb that myself for a fraction of the cost since I doubt that will be a cheap option.
    Originally posted by Andrew14 View Post
    Can someone clarify/confirm if the hull changed on the 2014 210 and 230? I heard / was told that the hull (portion in contact with the water) was the same as the previous 210s/230s, just the top deck changed (thus the wake would be identical to the 2013 models). Thanks in advance.
    The length and width dimensions are exactly the same and I don’t think the running surface changed too much so I bet the wakeboard wakes should be about the same as they have been. All along I had heard that the running surface was not changing at all but at least on the 210 it looks like they added some strakes in the aft section that match up with the NSS so I wouldn’t be surprised if the surf wave has been improved.
    Do these boats still have Hydro Gate or did they switch to NCRS?
    I don’t know too many people that hang their boats so lifting rings are probably no longer standard and I like the clean look without them. If you need them I think they are still an option because if you download the brochure it actually shows the lifting ring spacing for both boats. http://nautique.com/documents/brochu...0-brochure.pdf
    Shawn
    2012 Blue Metal Flake SAN 230
    • iamcdn
      • Mar 2013
      • 337
      • Penticton, Canada
      • 2013 SANTE 210 with NSS
      #47
      I heard the hull is basically identical but there is a small change to flatten the area where the hydrogate is so the hull doesn't have a little step there which is suppose to help reduce the wash while surfing. Otherwise, the hull is suppose to be the same.
      • xrichard
        • Aug 2008
        • 671
        • El Dorado Hills
        • 2023 G23
        #48
        I was wondering the same thing...but the photo of the NSS shows what looks like start of the same downward step/bulge as in previous year models.
        Middle of the second row of photos:
        http://www.nautique.com/models/2014-...r-nautique-210
        Previous boats:
        2015 G23
        2008 SAN 210
        2002 XStar
        1995 Sport Nautique
        • ES
          • Sep 2011
          • 234
          • Northern NC
          #49
          I find the new exterior quite bland...I miss the Nautique star/decals on the side. I guess that's why the photos include such bright colors...to add some visual punch.
          Definitely looks like they are creating some space in the 210 line to add a G21 that has the "wow" factor. Still, from a spec standpoint, the new 210 and 230 are phenomenal boats.
          • acs220
            • Jun 2008
            • 229
            • Yulee, FL (JAX)
            • 2012 SANTE 210 2008 SANTE 210
            #50
            The hydrodynamics of the hull should be the same but they are both definitely new. You can see from the pictures that the step where the top stripe used to be is gone. The "graphic" is actually gel coat and is raised off the main surface of the hull. Also, it looks like there is a recess in on the transom so that the new NSS covers would fit under the platform.
            2012 SANTE 210 (it's official)
            2008 SANTE 210
            • acs220
              • Jun 2008
              • 229
              • Yulee, FL (JAX)
              #51
              There is still a step and hydrogate on the 210's. Hard to tell if a step in the 230 pics, but there is a hydrogate lever in the photo of the "Nau-teak" flooring pic.
              2008 SANTE 210
              • Gary_93_Sport
                • Jul 2005
                • 22
                #52
                Does anyone have the 230 price sheets? Interested in base and option pricing. Thanks!
                • modog
                  • 22
                  • Michigan
                  #53
                  I love the new graphics/colors/redesign. For me, I never could get into the wild side decals; seemed a little too teenage focused. I think the new look is a lot classier; something I would be proud to own.
                  • tommy1005
                    • Jul 2009
                    • 73
                    #54
                    just wish they'd activated the build your nautique feature.....I know they have it ready to go, what's with the delay. Should've rolled it all out together like Mastercraft did with the X46
                    • modog
                      • 22
                      • Michigan
                      #55
                      I should clarify; I'd be proud to own any nautique--it's the boat not the decals!
                      • Vitty
                        • Jun 2013
                        • 9
                        • United States
                        #56
                        When does info on the 14' G's drop?
                        • Pjoachim
                          • Apr 2013
                          • 124
                          • Wisconsin
                          • 2001 CB ski
                          #57
                          Any other changes for the other boats being annouced?
                          Wisconsin
                          2001 196 Ski Nautique
                          2013 200V Team Edition
                          • MikeC
                            • Apr 2007
                            • 535
                            • Georgia
                            • 1999 Ski Nautique (Python powered) 2017 GS22 (sold) 2005 SV211 (sold)
                            #58
                            The '14 G's are already out, there was one on a trailer at the Gravel Tour in Orlando this past weekend.
                            • Andrew14
                              • Dec 2010
                              • 305
                              • Charlotte
                              #59
                              '14 G at the Gravel Tour? Anyone have any pics of the new 2014 G? Would love to see what it looks like.
                              • acs220
                                • Jun 2008
                                • 229
                                • Yulee, FL (JAX)
                                #60
                                I think the only diff in the G's are graphics, deck colors, and gel colors
                                2008 SANTE 210
