Originally posted by nyryan2001
View Post
nyryan I grew up in Duncan so I know that lake. Nice place but not much of a wind black!! LOL Come on down sometime. Texoma gets rough form big boats and wind also but we can find some places to ride..2016 G23 H6
2014 G23 550
2013 G23 450 (Great boat)
2000 SAN ( Loved that boat)
just curious if anybody knows how the wave would look with say 750 or 900lb bags in each rear locker with the stock 2800 full and using the NSS, and if the 450hp motor would be able to get it up to surfing speeds with the added weight in the back or would you need the LSA to get it done?
Cool! I grew up in Duncan too. Parents still live there. Used to ride out at clear creek a lot.Originally posted by Laketexoma View Postnyryan I grew up in Duncan so I know that lake. Nice place but not much of a wind black!! LOL Come on down sometime. Texoma gets rough form big boats and wind also but we can find some places to ride..2018 SAN 230
1981 Ski Nautique
Sold - 2011 Sport 200V
Sold - 2000 SAN
Tommy- read back thru this thread. The biggest wave... approx 4ft, is with 2900 OEM ballast, 1100 surf side + 500 or so on the other.2019 G23 450
2014 G23 550
2013 G23 450
2011 Malibu Wakesetter 247
2007 Yamaha AR210
Bump. Lots of requests for pics and G23 NSS wakesurf setup...go back to page 1.... page 5 has pics of it really dialed in.2019 G23 450
2014 G23 550
2013 G23 450
2007 Yamaha AR210
No, absolutely not.Originally posted by fatchance720 View PostWhen I tried that weight setting the wave did not form. I had to have more weight in the bow???
you are following THESE settings?
Full OEM ballast, all 3 tanks full
1100 extra in the surfside trunk, completely maxed out.
11.6mph -11.8mph
NCRS 5, SurfVerft 3. The real useable range is NCRS 3-5 and SurfVert 0-4 based on your pref.
All your extra folks and heavier gear on your surf side.
If you are still not getting a good wave you need to take pics of your wave and your setup and post them up here so we can see whats going on.2019 G23 450
2014 G23 550
2013 G23 450
2007 Yamaha AR210
I will try again, When I tried that I had full oem, 1100 completely maxed in port and 500 in starboard, nothing in the bow beyond oem. The wave would not form when I tried it. (that was before I learned to manually fill though, instead of using a user setting. I suppose it was possible that the bow was not completely full.
Also what do you do to reinforce the locker from caving in?
First, scratch the extra 500lbs in the other locker till you get things worked out. Def not necessary. Thats for a 4ft monster wave. And I doubt you could do that on the stock 2313 prop, seriously doubt you could get that up to 11.6mph. Sounds like you got stuck at 8-10mph.Originally posted by fatchance720 View PostI will try again, When I tried that I had full oem, 1100 completely maxed in port and 500 in starboard, nothing in the bow beyond oem. The wave would not form when I tried it. (that was before I learned to manually fill though, instead of using a user setting. I suppose it was possible that the bow was not completely full.
you need to double check these settings.... are you gettingthe boat up to up to 11.6mph? it may be too much weight unless you have the 2315. is your NSS on? and highlighted? with the arrow pointing to the correct side of the boat? Sounds either like you got stuck at 8mph due to the OEM 2313 prop, or one of your settings isnt right.
If you are getting stuck... scratch the 500 in the other locker and reduce weight to 750 in the surfside trunk and keep your NCRS at 0...untill you get up to 11.6, THEN tap it up to 4-5. that NCRS tab at 5 creates quite a bit of drag even from takeoff. You might need to do this till you get the 2315.
Nautique needs a software flash that will allow auto-NCRS to work with NSS. NCRS starts at 0 at takeoff... and then adjust to 4-5 when you speed control takes over at 11.6.2019 G23 450
2014 G23 550
2013 G23 450
2007 Yamaha AR210
Agree with nyryan on it sounds like you are not getting up to speed. If you don't hear the beep from the Linc system when you reach your set speed (if you have the beep turned on) the NSS will not engage.
Ok, either I haven't seen it yet or nobody has the same problem, what about the locker caving in when you use 1100 pound bags? I had to pull my 1100 and put 750 in because it was caving in the entire locker toward the engine.
What are people doing to reinforce it? Any applications that do not require drilling into the boat?
I am not sure if the G's are the same dividers as the 210s but I did the same thing as you can see here: http://www.planetnautique.com/vb3/sh...975#post203975 and it has worked awesome. 1100s in the 210 definitely cause a bow in the divider. I didn't have to drill anything but I was able to use the holes that were left from where the hard tanks were mounted, you wouldn't have that ability since I suspect the 1100s are going above the hard tanks on the Gs.Originally posted by fatchance720 View PostOk, either I haven't seen it yet or nobody has the same problem, what about the locker caving in when you use 1100 pound bags? I had to pull my 1100 and put 750 in because it was caving in the entire locker toward the engine.
It has never happend to me... Not once....and I completely fill mine up...
guys on the Malibu Forum have reinforced the panels with 3-4 3/4" square tubing that run along the panels.... And along the tracks, all it can't skip and jump the tracks.2019 G23 450
2014 G23 550
2013 G23 450
2007 Yamaha AR210
- Feb 2010
- 921
- Phoenix AZ
- 2013 G23 550 hp (ordered and awaiting delivery) 2002 Super Sport (coverted into a SAN) 330 hp Excaliber 1994 Sun Tracker Party Barge 115 hp 1989 Horizon 200 Four Winns - sold 1989 Regal Commodore 280 - previous Possibly looking into picking up a 70'2-80's Nautique to rebuild as a ski boat
Mine bows significantly. I am going to try the trapezoidal Ronix bags that fill 1100 in 3 minutes, but I also ordered a second set of dividers to dissipate the pressure of the sacs. Should be in today, we will see how it works. Also, my dealer just got the surf pipe from Nautique and it will be installed next week. Will post pics.Eric, Phoenix AZ
G23 550 hp (finally here)
2002 Super Air
