Perfect Pass Digital Pro
  • pdxCC
    • Aug 2009
    • 143
    • Portland, Oregon
    • Current -> 01' Air Nautique Previous - 93' Ski Nautique
    Does anyone know where I could find a Digital Pro control box to upgrade from my wakeboard pro? My 01' Air Nautique needs it to help with my new Slalom addiction...
    ____________________________________________
    Current Boat --> 01' Air Nautique (April 12' to current!)
    Previous Boat - 93\' Ski Nautique Closed Bow ( Sept' 09 to March 12')
  • Miljack
    • Dec 2004
    • 1634
    • Charlotte, NC
    • '08 230 TE ZR6
    Are you running the course where you need to add magnetic timers? If not, Wakeboard Pro has "slalom" mode. What version is your setup?
    2008 230 TE-ZR6
    • pdxCC
      • Aug 2009
      • 143
      • Portland, Oregon
      No courses in this boat. I think it's 6.5 but all I know how to set is rpm mode. The pull is just too soft.
      • Quinner
        • Apr 2004
        • 2246
        • Unknown
        • Correct Crafts
        Had the same thing and switched it over to "Slalom" mode, worked much better. Use trick settings for the slow speed pulls.
        • pdxCC
          • Aug 2009
          • 143
          • Portland, Oregon
          Unfortunately mine is the older pre-2005 wakeboard pro with only the speed and rpm options. There is no slalom mode. Hence why I want to upgrade... Any ideas?
          • swc5150
            • 2240
            • Eau Claire, WI
            • MasterCraft Prostar
            You could look for a Stargazer master module set up on ski-it-again.com, and swap yours out? If upgraded my '07 196 Digi Pro to SG for $200 from a used system. Now that people are swapping SG for Z Box, you may find a good deal on SG out there.
            '08 196LE (previous)
            '07 196LE (previous)
            2 - '06 196SE's (previous)
            • vtjc
              • Feb 2011
              • 61
              • Vermont
              • 2008 Correct Craft Ski Nautique 196
              You can switch a mechanical Wakeboard Pro module to Digital Pro, with resets, I did this with the PP 6.5 installed in my ’99 MC. Contact Perfect Pass or review the manuals http://www.perfectpass.com/?q=manuals. You would just need a magnet sensor if your running through a course with magnets. Sorry, I don't remember the steps I did in '04.
              Previous Boats:
              99 MasterCraft SportStar(95-97 ProStar Hull)
              98 Moomba Boomerang
              88 MasterCraft Powerslot
              • pdxCC
                • Aug 2009
                • 143
                • Portland, Oregon
                Vtjc - did you swap modules? Or was it a flash of the memory?
                • hyparks
                  • Feb 2011
                  • 302
                  • Brownhills, United Kingdom
                  • 2001 Super Air 210
                  If I remember from my wakeboard pro manual it says you can select either wakeboard or digital pro by pressing a couple of buttons.
                  This is what it says in the manual. Go through this on s wakeboard pro 6.5 then right at the bottom it allows you to switch to digital. Hope this helps
                  Resetting a Wakeboard Pro (System Reset) Version 6.5 NG (Graphic Display) You can do a System Reset by pressing and holding the ON/OFF & MENU keys together as you power-up the system (turning ignition ON or to ACC). Continue holding keys as the skier moves across the screen and system information is displayed. The following screen should now appear. NOTE if this screen does not appear turn off the ignition and try again, making sure to hold ON/OFF and MENU keys.
                  PerfectPass Control Systems Press the UP key to continue the reset
                  Press the UP key to reset RPM Baselines and speedometer calibrations to factory settings Press the UP if you have a standard engine. Press the DOWN key if you have a 6.0L or 8.1L NOTE: Message will vary on OEM versions
                  Press the UP key to display the speed in MPH or the DOWN key to display speed in KPH
                  Press the UP key to reset as a Wakeboard Pro or the DOWN key to reset as a Digital Pro
                  Current
                  2001 SAN 210, GT40
                  Previous
                  1994 Mastercraft Pro Star 190
                  • vtjc
                    • Feb 2011
                    • 61
                    • Vermont
                    No new hardware or software, just reset to switch. NG = New Gauge, the double line display.
                    Previous Boats:
                    98 Moomba Boomerang
                    • pdxCC
                      • Aug 2009
                      • 143
                      • Portland, Oregon
                      Any idea if this works on the older single line display?
                      • vtjc
                        • Feb 2011
                        • 61
                        • Vermont
                        Yes, it worked on 6.5 single line display. Where you able to contact Perfect Pass to get the steps? Jamie
                        Previous Boats:
                        98 Moomba Boomerang
                        • pdxCC
                          • Aug 2009
                          • 143
                          • Portland, Oregon
                          Not yet. I am going to try it tonight!
                          • east tx skier
                            • Apr 2005
                            • 1561
                            • Tyler, TX
                            To do a system resent, as soon as you turn on the key, you hold down Menu and On/Off for about 4 seconds until it beeps. It will ask you if you want to reset, and you select ^ for yes. On reset, select 3 event and you're good to go. As long as you are not in the course, you should not need the magnet sensors.
