Originally posted by Mikeski
View Post
Another plug for 343. Very happy with our set-up...hole shot, power, fuel economy and maintenance are great. I do have a little dissappointment with our top end speed...but realize this is not soley engine related and rarely get up there, so not a priority at the moment.Peace..
We've had two Sport 200's, both with the 343. I have also skied behind one with the 409. As far as I can see, the only reason to buy the 409 would be if you're barefooting. Top speed difference is about 3 mph. Our 343's have had more than enough power out of the hole. Tough to justify the price difference and my understanding is it makes very little difference on resale.2012 Sport Nautique
2011 Sport Nautique (Sold)
2000 Malibu Sunsetter LXI (Sold)
Thank you - great advice!Originally posted by Dinsdale View PostWe've had two Sport 200's, both with the 343. I have also skied behind one with the 409. As far as I can see, the only reason to buy the 409 would be if you're barefooting. Top speed difference is about 3 mph. Our 343's have had more than enough power out of the hole. Tough to justify the price difference and my understanding is it makes very little difference on resale.
I have a question about fuel consumption. I have driven 230s with both the 343 and the 409, the 409 used less fuel per hour than the 343 did (as a matter of fact I was amazed at how little the 409 used). It's a much heavier boat than the 200 so that may be a factor. But I wonder what the fuel burn is on the 200 with each engine considering that, as Mikeski has said, the 409 is based on newer technology.
I would also like see if anyone has "real world" fuel consumption numbers for the 343 and 409. Let's face it when spending this much on a boat fuel consumption does not play a big part in the purchase. It does however create another consideration for engine choice.
It takes the same amount of power to push the hull through the water with either engine, except for very minor changes due to different engine weights, until you obviously are asking for more than 343 HP.
As you approach WOT, all engines run richer. It stands to reason, the 343 would start to richen the fuel to air ratio at a lower power level than the 409. So, running at the "sweet spot" above where a 343 starts to run richer, but before the 406 does, I would expect better economy out of the 409.
Consider this.
My 1997 Ski Nautique averages about 3 GPH. This year, I paid between $3.67 to $4.27 per gallon, for gas. Call it $4.00 per gallon. That is $12.00 per hour, for gas. Lets say you are out for 2 hours in your boat with a few friends, or your family. Now, how much would it cost to take those people to a movie?
Correct... 409 is a few lbs lighter than the 343.Originally posted by Quinner View PostYou sure about the 100lbs more? The aluminum (409) vs CI heads (343) should make it lighter, not heavier. Now there is additional components for the closed cooling, but even that may just make it a wash.1990 Ski Nautique
NWCT
Not according to the GM website that was posted in an earlier post.
343: 432 lb (196 kg)
6.0L: 539 lb (245 kg)
http://gmpowertrain.com/Libraries/Ma...rine.sflb.ashx
http://gmpowertrain.com/Libraries/Ma...rine.sflb.ashxNautique Promo Team Washington/Oregon
