Originally posted by sstexan
View Post
I just bought the same truck only a year older. Rides rougher than my 2005 F150 but it will pull my G23! I'm getting the same mileage and am in the same State. Also using the trailering option helps both acceleration and stopping. The only thing this truck needs is a bigger fuel tank! 26 gallons is to small!!!2013 G23 450 with NSS (175hrs) and still have the original prop
2010 SANTE 230 343 (280hrs)
What nyryan said. That set up is an accident waiting to happen.
Get the truck and trailer level by sorting the suspension and hitch out.
The trailer bunks appear to protrude several inches past the transom. Slide the boat back until the bunks are flush with transom.
With the G23 behind my F150 I had to get a three inch drop and turn it over to get the trailer level. Also, it was hard to find an 8000+ pound 2" ball locally. Had to order it from the web. Boatmate needs to go to a 2 5/8" on G trailers.2013 G23 450 with NSS (175hrs) and still have the original prop
I will +1 on this statement. There is no way that truck should be pulling that boat the way it is sitting now. It is a far stretch with the 5.0 to pull that boat period, but without airbags or something to stop that squat it is just downright dangerous. No offense to Kporsch but I hate seeing that because it puts other people on the road at risk other than just you.Originally posted by nyryan2001 View PostWow, that squat on your truck is bad. I tow with a Tundra and it's not that bad.
if you wanna keep that F150, suggest you look into adding Roadmaster Active Suspension. You need it, that is not a safe tow. Emergency braking would be a trainwreck like that. And you don't have the hitch at the proper height, slightly above level for max braking. Is your hitchrated for 8000??
any chance you have ran your G across the scales for an actual weight?
What bran trailer is that? It looks like the boat needs to slide 6-10" to the rear to reduce tongue weight. Is that bow stop adjustable? Ubolts?
Y'all can relax. My truck barely squats at all. It's hard to tell from the picture but the parking lot is sloped for drainage and is why it looks like that in the picture. Yes the hitch and trailer and truck are all rated for the weight. It is a 2 5/8" ball. The braking action on that trailer is awesome and I can actually probably stop faster than with just the truck.Originally posted by UofM21 View PostI will +1 on this statement. There is no way that truck should be pulling that boat the way it is sitting now. It is a far stretch with the 5.0 to pull that boat period, but without airbags or something to stop that squat it is just downright dangerous. No offense to Kporsch but I hate seeing that because it puts other people on the road at risk other than just you.
What trailer is it? I would like the 2 5/8 ball.2013 G23 450 with NSS (175hrs) and still have the original prop
Originally posted by Kporsch View PostY'all can relax. My truck barely squats at all. It's hard to tell from the picture but the parking lot is sloped for drainage and is why it looks like that in the picture. Yes the hitch and trailer and truck are all rated for the weight. It is a 2 5/8" ball. The braking action on that trailer is awesome and I can actually probably stop faster than with just the truck.
Riiiiiiiight. You've got it all under control, just a bad pic. Not only do you not have the proper hitch height, terrible squat indicating excessive tongue weight on likely and under rated hitch, and the boat not properly positioned on the trailer, case of beer says you're over your tow capacity. Big time over is if you have the 3.55 gears. Likely right at max if you have the 3.73s with full gas and a few folks and gear in your truck/boat, assuming a 8300lb boat and trailer combined tow.
Not it quite as bad as the guy towing the G25 with the 6.2L Raptor. 450hp good to go right?2019 G23 450
2014 G23 550
2013 G23 450
2011 Malibu Wakesetter 247
2007 Yamaha AR210
My Ramlin uses the 2 5/8" ball.Originally posted by swankster View PostWhat trailer is it? I would like the 2 5/8 ball.2021 G23 450 - Current
2019 G23 450 - Sold
2018 G23 450 - Sold
2017 G23 450 - Sold
2016 G23 450 - Sold
2014 G23 550 - Sold
2013 G23 450 - Sold
2012 210 - Sold
2012 200 Mapple - Sold
2011 230 - Sold
Wow what's with the negativity? I'm not telling everyone to go buy an F150 to do daily towing. I'm just stating for my purposes it does OK. Of course I got the 3.73s (I had the 3.73s in my previous 4 f150s as well). And no I'm not over the max tow rating of 9300 lbs for 4x4 5.0 145" WB.Originally posted by nyryan2001 View PostRiiiiiiiight. You've got it all under control, just a bad pic. Not only do you not have the proper hitch height, terrible squat indicating excessive tongue weight on likely and under rated hitch, and the boat not properly positioned on the trailer, case of beer says you're over your tow capacity. Big time over is if you have the 3.55 gears. Likely right at max if you have the 3.73s with full gas and a few folks and gear in your truck/boat, assuming a 8300lb boat and trailer combined tow.
I will get a good pic of the truck not squatting in the spring of 2015 (which is the next time I actually plan to tow the boat). The squat is no different than the OP's first pic.
9300 is for a completely empty truck, full gas and and 175lb driver only.
Add 3-4 additional folks their bags, few tools, hitch... Your truck options and you are within 500lbs if you run a skinny boat gear wise. Not trying to be negative... Want you to be safe brother. Let one thing go wrong... Flat tire, emergency stop, bow strap break while ill balanced etc etc.2019 G23 450
2014 G23 550
2013 G23 450
2007 Yamaha AR210
Just checked the hitch on my 06 Duramax the other day, that little thing was only rated at 7500 lbs. Pretty weak I'd say. Just ordered a Curt 16,000 lb hitch online, then had to find a 16,000 lb rated receiver and ball. All Curt products. I should be up to code once getting those installed. If ya have a big boat, check your hitch. I was a bit surprised in mine.
2014 G23 450 Coastal Edition
2013 G23 450 Coastal Edition
2010 SANTE 230
2007 SANTE 220
2003 SANTE 210
If any of you guys want to do the single best mod you can ever do to improve your trucks towing capability.......GET SOME AIRBAGS.
I leveled my 2006 F150 so anytime I had a load on it or towed anything, the rear end squatted badly. I couldn't stand it. So I did some research and found an auto leveling kit with Airlift bags. IT WAS AWESOME!
Because I had the bags always loaded with 10lbs of air, to keep it at the desired level when not under load, it had a wonderful side effect that greatly Improved ride quality of my truck. It all but wiped out the rear end chatter that is prone to leaf spring equipped trucks when not under load.
Take a look at the pics.
No load, leveled. Set up with 10lbs of air at all times.
Heres the terrible squat when the the boat was hooked up. The air bags had not inflated yet.
Now, here is is 10 seconds after the key is turned on. Its auto lifts to level.
A $750 wellllllllll spent.
