I put a new cam in my boat this fall. Currently, its a 351W with stock GT40P heads. When I say stock, it has the stock valve train components as a 2000 ford exporer. The cam I chose is made by cam research (they said its an awesome cam for ski boats). The specs are:
intake lift .49
exhaust lift .49
intake duration 278
exhaust duratation 282
Intake duration @.050 216
Exhaust duration @ .050 220
lobe separation 112
recomended seat pressure 95lb
recomended open pressure 295lb
I want to use the stock gt40P valves which have an installed ht of:
Intake 1.780"
exhaust 1.690" (without the exhaust rotator)
The stock gt40p springs don't seem to satisfy the cam requirments. The stock gt40p springs yeild:
intake seat pressure (@1.78") 76lb
intake open pressure (@1.29") 227lb
exhaust seat pressure (@ 1.69") 67lb
exhaust open pressure (@ 1.20") 208lb
Has anyone done the GT40P/cam upgrade and changed valve springs? If anyone used a simular cam as I have chosen, what springs did you use? I have set in mind, but reinforcement from others would help me out alot.
intake lift .49
exhaust lift .49
intake duration 278
lobe separation 112
Intake 1.780"
