Wires for Ballest control
  • Lvnspeed
    • Aug 2008
    • 393
    • Smith Lake AL
    I have a 2003 226 and it has on the dash 3 push buttons for the filling ballest tanks. Where are these wires or wire colors in the boat? I am adding ballest pumps and fat sacks and would like to use these controls. yes I plan to add relays also
    2003 226 LE
  • mnwakerider
    • May 2011
    • 271
    • Minneapolis, MN
    In my 2003 SAN 210 LE (no belly tank) the belly leads were on the driver front side of the gas tank. Had to pull the center floor section to get there. You will see some black wire looms running from helm to stern. My leads were outside of this. I had rear tanks so it was easy to find those (just pulled off of the existing pumps). They are all white with a colored strip to ID + (white with purple, green, etc).
    I got a heads up on all of this by email local dealer and then they got me in touch with the factory. They emailed me schematics to aid in the search. Could be worth trying if you strike out here.
    Good luck!
    • Lvnspeed
      • Aug 2008
      • 393
      • Smith Lake AL
      2003 226 LE
