Clutched water pump for ballast!
  • Tyler230
    • Nov 2011
    • 16
    • Alberta Canada
    • 2000 Suoer Air -Python 2012 230 Team -Supercharged
    I was thinking about potentially using additional magnetic clutched raw water pump(s) to fill and empty my ballast. Has anyone heard or seen anything like this? Just thought I would try bouncing the idea off people and get a discussion going!
  • mastercard
    • Jun 2011
    • 54
    • Tyler/Carthage Tx area
    • 2000 SAN
    I like the way you think. I have thought about it as well but thats about as far as I've gone with the idea.
    2004 SANTE
    2000 SAN Sold
    • gsxrgessler
      • Jan 2005
      • 45
      • Minneapolis/St. Paul
      • 2001 Super Air
      +1 on the thought. Sounds interesting, not reversible...
      • Miljack
        • Dec 2004
        • 1635
        • Charlotte, NC
        • '08 230 TE ZR6
        I see using an A/C type of clutch, and if you got creative with a drive pulley system, could figure out a way to reverse it! We saw a fire boat pumping @ our lake this summer and it got me thinking as well...
        Maybe the easiest way to empty is to run a pump facing the opposite direction, and then clutches on both pumps...hmmm.
        2008 230 TE-ZR6
          • 2908
          Just run valves to reverse the water flow.
          But my 4 year old impeller fill, aerator drain system has been trouble free since I converted the fill aerators and eliminated the flow wrong valves. This is probably an easier solution.
          • Chexi
            • Aug 2026
            • 2119
            • Austin
            • 2000 SAN
            Methinks this would be a very expensive project.
            Now
            2000 SAN
            Previously
            1999 Air Nautique
            1996 Tige Pre-2000
            • C.A.
              • May 2011
              • 32
              • Umatilla, FL
              • 2015 G23 Coastal 450
              Here's the pump: http://www.johnson-pump.com/JPMarine...5000-5006.html
              I'm sure it's expensive..... and mounts would have to be fabricated..... but I like the idea!
