Warm Water at drivers feet?
  • themaestro
    • Sep 2010
    • 36
    2003 Air 216 with PCM 330 Excalibur
    The carpet at the drivers foot well area is getting soaked by water coming up from underneath. The water is warm, like its from the engine. Looks like a hose runs forward from the motor going in that direction. Where is this water coming from? Its enough water that when you push with your hand the water pools. I can't get a good look into that compartment to see whats leaking.
  • jhiestand
    • 786
    • Columbus, Ohio
    • 08 Super Air 210
    Your heater core has sprung a leak, most likely.
    '08 Super Air Nautique 210
    • johnboyy7
      • Oct 2009
      • 409
      • houston
      thats what mine did..... heater leak.
      04 SANTE 210
      89 SPORT
        You can take the heater out yourself, and replace the core. Heatercraft makes the heater for boats.
        I recently replace the core in a series 300 heater, and the design of the core has changed, The old type was a honeycomb type of construction, and the new design is a copper tube, with aluminum fins.
          • Apr 2026
          Temporarily, you can get a double-hose barb connector and connect the 2 hoses going in and out of the heater core. Be sure to hose clamp them. This way you can continue to use your boat until you get a replacement heater (if you decide to even replace it). It's a good idea to keep one of these double hose barbs on the boat in case this happens again. Saved my arse once.
          • themaestro
            • Sep 2010
            • 36
            You guys are the BEST. Thank you! I leave for Lake Powell tomorrow and I need a quick fix. I won't be needing a heater at Lake Powell!!
            • johnboyy7
              • Oct 2009
              • 409
              • houston
              when it comes time that you decide how to fix it, there are several threads about replacements. you can buy a heater craft for 100+ or from Oreileys ect for 15-20.
              as chexi suggested, i to took 2 sets water hose fittings to bypass my heater. i cut mine at the motor for ease to get to. i usually leave mine bypassed except in the months that its needed.
              have fun at powell. i hope to go there one day.
              04 SANTE 210
              89 SPORT
