The rear bilge pump in my '08 211 is running constantly and thus draining the battery. It's going to take a while for dealer to get a new one. Dealer recommended just disconnecting the rear pump and continuing to use/store the boat as normal and that the front bilge will be able to take care of everything. Makes sense assuming that the primary purpose of having both is so that one can act as a backup. My concern is if the boat fills with water during a rain (boat is stored in the water in an uncovered marina slip) and gets 'back heavy', eg, water builds up in the rear, and the rear goes down before the front bilge turns on.
Valid concern? Likely? Am I safe using the boat and leaving it in the marina until the replacement pump comes in?
Thanks,
Thanks,
