Originally posted by TW
View Post
Whatever you call the frames (that lift the seat up off the floor), the older style is metal, the newer is plastic- so neither rot. The base itself (what the vinyl staples to) is wood on both versions. CC didnt go composite on that piece until '93.
I dont buy the fact that the 1.23 trans hurt the top end at all. Maybe your experience is limited to a few select boats? Hull variations can account for several mph difference in top end speed, even with the same powertrain. Our '88 was only good for 42-44. 2 of my buddy's '86's run 45-46 on the GPS. Ive seen stock engined '89's run 47. I have not seen any correlation between the 1.23 trans and lower top end speeds. My buddy has a '94 base model SN with a 240hp 351w and 1:1 transmission and its slower (42mph) than my '90 was with the stock motor (43mph), which has the 1.23... and my '90 has a slow hull in every sense of the word.
As for "something for nothing" I cant say youre right there either... theres a reason why CC has been using the 1.23 in most of their direct drives since '89- its a great feature! It offers an improved holeshot without a top end penalty. MC has essentially switched their Powerslot to a 1.26 (from a 1.5:1) in recent years, so that must be pretty close to the sweet spot for this type of hull. Some of the fastest Correct Crafts I know (mid to upper 50's) have the 1.23, FWIW!
