ZO surging solved & 2009 - future SAN 210 - ZO only
  • Nordicron
    replied
    Originally posted by Paxdad View Post
    Thanks the quick reply is there a reference thread that you can point me to on how to check the software version I have as well as how to update if needed?
    Easiest thing to do is go to the zero off website and download the PDF user manuel. It has directions on how to update and how to go into diagnostics screen to check software. But really it's not a user update process prob best left to a dealer.
    Leave a comment:
  • Paxdad
    replied
    Leave a comment:
  • Nordicron
    replied
    Surging is the bow bouncing up and down when locked on at your set speed when zero off is engaged. This is called porpoising and can usually be controlled by moving the hydro gate forward or turning. Happens more in choppy rolly water and when u run more stern ballast than nose. And u have the old style antenna. Try the software update first a lot of people have success with that.
    Leave a comment:
  • Paxdad
    replied
    I have attached a photo of my antenna. Do I need to have it replaced? Please describe the surging that is noticed.
Name:	GPS Antenna.jpg
    Leave a comment:
  • xrichard
    replied
    The old style antenna is a round puck...if yours is round like a hockey puck, it's original
    Leave a comment:
  • Paxdad
    replied
    Since I am a recent purchaser of an 08 210 SANTE how would I know what antenna I have?? Mine is mounted/ located just beyond the driver window on the flat area near the mooring cleat. When talking about surging I dont' think that it surges with stock ballast but I can tell that it seems like that there is a subtle miss in the engine exhaust tone. Please describe the surge that everyone is talking about.
    Thanks.
    Leave a comment:
  • xrichard
    replied
    Unless things have changed, you need a Diacomm cable to upgrade...or ZeroOff will do it (at least they used to) if you send the unit to them. Most dealers have the right cable--but some (like my old dealer) don't. If you have to buy it, I believe it's +/- $250. I had CC West upgrade mine several years ago and it only took a few minutes.
    Leave a comment:
  • Dave Rittiman
    replied
    Scott
    How do you upgrade the firmware on the Zero Off is there a USB connection on the back of the unit or something > ? Looking on the site it does allow you to download the software or at least request the latest S/W.
    I rather try and upgrade the firmware first and see if it fixes the problem. We went last weekend and had about 3000 pounds in the boat and were Surfing and it was really bad.
    How long did it take i would assume it pretty easy.
    No i did not do the upgrade myself. I am on rev q now, i think. We ran full belly and about half full on 1100 sacs in the back and i was quite happy. No noticiable purpoising at all. You may be right. But i will take "big improvement" and save the $450
    https://www.zerogps.com/product/r2-antenna-and-harness
    Leave a comment:
  • scottb7
    replied
    Leave a comment:
  • Nordicron
    replied
    I decided to try upgrading zero off software and skip the antenna. I am very happy with the result.
    Did you do this yourself? What software part number are you showing now? You need to go into diagnostics section to see. I have the E1886200A software and yes it was a big improvement when running stock ballast and 1579 prop but with added ballast and larger prop you will still have issues.
    Leave a comment:
  • scottb7
    replied
    Leave a comment:
  • H2O
    replied
    I cannot get Zero Off to respond to my email. As a matter of fact email addressed to ericf@zerogps.com is returned "not deliverable". Is the address above in Waterford, MI, where headunits are sent to be updated for the R2 antenna?
    Leave a comment:
  • Bevan
    replied
    Here ya go...
    Eric D. Faccenda
    Technical Service Engineer
    Aquastar, Inc. - Zero Off
    6650 Highland Rd. Suite 202
    Waterford MI, 48327
    www.zerogps.com
    1.248.886.0849 (Local)
    +44.151.324.1500 (U.K.)
    1.847.620.2560 (Fax)
    ericf@zerogps.com
    Good luck!
    Leave a comment:
  • ericchile
    replied
    Right around 22mph. Do you still have a name and phone number? If so could you PM me with it?
    Leave a comment:
  • Miljack
    replied
    I had a question on a newer head unit and the software, and ZO was pretty responsive. I think I sent them an email from their site first, then got an email to call somebody to discuss it. He checked on it and got back to me in a few days.
    Also, what speed are you riding?
    Leave a comment:
