ZO surging solved & 2009 - future SAN 210 - ZO only
  • hourglass
    • Mar 2010
    • 248
    • lower bama
    • 2005 SANTE
    #91
    seriously. all of ya'll either need to shut up and fork over the money or get together and force c.c. to do what's right. i would go with option B first. i bet if your dealers and the factory, along with zero off got letters from attorneys they would be more inclined to do something.
    • JWAT
      • 527
      • NE Indiana
      • 1997 Super Sport/Super Air Nautique 2008 Super Air Nautique 210
      #92
      I already forked over the money as noted above...
      2008 Super Air Nautique 210TE
      • Bevan
        • Mar 2007
        • 439
        #93
        Originally posted by Latonkaboarder View Post
        I had my system upgraded with the software last year and it still porpoises. I just deal with it like the rest of you and use the hydrogate to smooth it back out. I wonder if the upgrade this year is any different and if it will help as Bevan says it did on his? I wish I had perfect pass instead of zero off.
        Honestly, the improvement on my boat with just the software upgrade is like night and day, i couldn't be happier!
        • Chad52
          • May 2004
          • 295
          • Huntsville, AL
          • 2008 Super Air Nautique 210 2003 Super Air Nautique Team 210 2001 Super Air Nautique Team 210 1999 Super Air Nautique 210 1994 Mastercraft Prostar 190 1992 Manta Ray 189 Sport
          #94
          I sent Larry Shea at Correct Craft another email. I'll let you know if anything comes from it...
          Chad
          • highrock
            • Sep 2008
            • 206
            • Salisbury, NC
            • 1995 Ski Nautique (2017-Current) 2015 G21 (2016-Current) 2010 230 (2012-2016) 2008 210 (2008-2012)
            #95
            I had my software updated on my 08 210 last weekend. I did not buy the new antenna and wanted to at least try just the update and see how it worked.
            I would recommend trying that first as it really helped on my boat. It does make a world of difference with just the update. Going through rollers you do not have to mess with the gate anymore to get it from bouncing...it does it a couple times then levels out.
            This is with about 3000 Lbs. of ballast in the boat as well if anyone is wondering and riding 23.5-24.
            Plus its free if you have access to a cable to plug up to the boat!
            2010 Super Air 230
            2008 Super Air 210
            • Quinner
              • 2246
              • Correct Crafts
              #96
              Has anyone experienced the porpoising when the boat is being operated within the weight limits on the coast guard plate, that would be the combination of Ballast weight + Human weight?
              Using Tundra's example with his Jap truck, imagine if he added thousands of pounds over capacity in the bed of his rice burner, it would snap in half, maybe that will be toyota's next recall, LOL.
              Tough deal either way, not sure I would be too happy if my brand new very expensive boat required a $500 "upgrade" and as mentioned by another poster, on an already expensive optional item, when being used in the same fashion as their own "team riders".
              Good Luck, hope you all get it worked out!
              • ericchile
                • 283
                • Utah!
                • 2009 SANTE 230
                #97
                Well great... bought a very slightly used 2009 230 which never received this 'update'. One request by my wife was that the cruise system worked so that I wasn't yelling at her when I get in the boat. I knew I would need to update this but it looks like the cost is even more now.
                $450 :-0 https://www.zerogps.com/product/r2-antenna-and-harness
                How can a wire harness and antenna cost more to make then some laptops and ipads? I just don't understand the cost. Are they turning a profit of this problem?
                • Miljack
                  • Dec 2004
                  • 1632
                  • Charlotte, NC
                  • '08 230 TE ZR6
                  #98
                  @Ericchile, did you have a chance to ride your 230 before you winterized? With stock ballast, you won't need the update, if you plan on running fly hi add on, you will want to have it done.
                  You can get a little better price from Whitelake/Nautique Parts, but not much. WL is "selling @ cost" because of the widely known issue, so ZO must be close to that position as well.
                  I agree, the price for the wiring harness and antenna seem really out of line for what is there, but I think there's a gyroscope in the new antenna and is a custom unit for ZO...
                  2008 230 TE-ZR6
                  • ericchile
                    • 283
                    • Utah!
                    • 2009 SANTE 230
                    #99
                    Yea we took it out 5 times after buying it. Since I knew about the issue I was really paying attention. With a full ballest and no one in the front and me wakeboarding behind, my wife was not happy as I was not happy getting out of the water. We have used a friends out board boat for the past 3 years which had no cruise and was pretty sensitive. She said she would only support me buying a boat if she didn't have to worry about me being upset when getting out of the water. The pulsing was very noticeable, especially when the boat hit chop from another boat. It would then pulse for a good 2 min before settling down.
                    • Miljack
                      • Dec 2004
                      • 1632
                      • Charlotte, NC
                      • '08 230 TE ZR6
                      #100
                      What prop is on your boat? You had ballast in the belly tank full? Mine has only "porpoised" occasionally, and was caused by hitting rollers from other boats. I was able to correct using the Hydro Gate, by pushing forward to position one. What speed do you normally ride? We are running from 20.5-23 mph without issue.
                      My riding buddy has an '08 210 with the fly hi add on system, and we noticed that his would porpoise with the 1235 prop, but not with the 1579 prop. This was with the add on ballast full only. Stock ballast the 210 doesn't porpoise with either.
                      2008 230 TE-ZR6
                      • Paublo
                        • Jul 2006
                        • 51
                        • Arizona
                        #101
                        If it ever porpoises, regardless of which prop, extra weight, or whatever else, you will not be happy until it is fixed. On my '09 210 the first year it only happened a couple of times and was fixed with adjusting the hydro-gate. The next year it started to happen more often. It just frosted me that I had to pay that much money to fix a new boat, so I put it off for a few months. Finally I bit the bullet and changed out the antenna and software update. It has never happened again and I soon forgot about having to spend the money. So I am happy again with my boat and Correct Craft- until you guys bring this thread up again and it gets me going all over again about spending that much for a fix that should have been a warrantee issue.
                        The moral of the story is to just fix it and hope this thread dies.
                        • ericchile
                          • 283
                          • Utah!
                          • 2009 SANTE 230
                          #102
                          My prop is 1235.
                          Doing my best to keep the thread alive. I emailed the ZO guys from their website when I first responded to this thread about the price. Haven't heard back :-(
                          • Miljack
                            • Dec 2004
                            • 1632
                            • Charlotte, NC
                            • '08 230 TE ZR6
                            #103
                            I had a question on a newer head unit and the software, and ZO was pretty responsive. I think I sent them an email from their site first, then got an email to call somebody to discuss it. He checked on it and got back to me in a few days.
                            Also, what speed are you riding?
                            2008 230 TE-ZR6
                            • ericchile
                              • 283
                              • Utah!
                              • 2009 SANTE 230
                              #104
                              Right around 22mph. Do you still have a name and phone number? If so could you PM me with it?
                              • Bevan
                                • Mar 2007
                                • 439
                                #105
                                Here ya go...
                                Eric D. Faccenda
                                Technical Service Engineer
                                Aquastar, Inc. - Zero Off
                                6650 Highland Rd. Suite 202
                                Waterford MI, 48327
                                www.zerogps.com
                                1.248.886.0849 (Local)
                                +44.151.324.1500 (U.K.)
                                1.847.620.2560 (Fax)
                                ericf@zerogps.com
                                Good luck!
