i think he was agreeing that the new 220 was designed to be the boat that replaced the legacy 210. i dont think he was comparing the new 210 to the legacy 210.
and i will still stand by my previous comment: everyone is a naysayer about the storage/trashcan humps in the 220 until they spend a day in that boat. i would even venture to guess that miljack hasnt spend 8 straight hours in a 220 (not calling you out, just tryting to make a point on). when weighted correctly, that boat has the steepest wake a nautique produces second only to the legacy 210.
i will agree that walk through/full lift engine hatch design of the 230 is superior to any other option from any other manufacturer out there. they need to ditch the stern cooler...its useless, the engine heat bakes the ice right out of there, and when are you really speding enough time back there to enjoy a complete beverage? make it a reach through for life vests, surf ropes and wake skate shoes.
the helm forward design of the 220 actually allows for a longer cockpit than the 230. if they did move the bow forward on the 230, they could get the drivers seat out of the way of the reversibile bench. look at the pic below. even though the 230 is a wider boat, the leanback is narrower and allows the driver's seat to protrude as indicated by the green circle. whereas i can set two people relaxed on my 220 bench, only one can sit comfortably and lean back on my 230 bench. the light blue circle indicates wasted space behind the starboard lean back. stealing a trick from my 220, i relocated my trash can there so it is easy access for all in the boat.
when you look at the 220 you see that the driver's seat does not protrude into the rear bench area. additionally, you have the inboard padding of the lean backs to rest against (as indicated by the green circles) and the tops of the lean backs to rest your arms on without fear of violating any "man rules." finally the blue arrow indicates the forward facing padding which is key if you like to face forward. finally they add an additional storage point to keep people from having to climb into the glove box to fetch their phones, etc.
am i fan of the lean backs? you be the judge. all i know is that i have more than 400 hrs on my 220 and 175 hrs on my 230. from inside the boat, the 220 is more functional and comfortable. from the sundeck back, the 230 is more functional and comfortable.
