Hello,
I just joined the forum and will be buying a boat hopefully soon. I am looking for some info in the meantime. Can anyone tell me the draft of the 02 & 03 206 Air Nautique? I'm assuming the tower would make it sit a little lower in the water?
My lakefront channel is very shallow (at an alltime low of 30", but maybe some room to gain in the bottom muck?) so I'm also hoping to get some insight into minimum water depth for a lift. I'd like to hear your feedback as to how shallow you have been able to have a lift and still drive the Nautique onto it.
So far I've found a lift with an 8" clearance height at the base or frame rails, but I'm trying to figure out how low below the water the bunks need to sit in order to get the hull to clear. My thought is that in order to clear the base of the lift with the fins I need a water depth of 8" plus the draft plus another inch for clearance (and that is the minimum due to fluctuating water level and weight/draft of the boat with gear). If the lift sank deep enough into the muck I feel like the fins could possibly clear the base, but I need to know how low below the water surface the bunks would need to be in order to clear the actual hull. Thank you in advance for your thoughts!
