Today I noticed that my boat was going way faster than what the perfect pass was showing. The boat was also pumping out a ton of water. I checked it out later and noticed that the paddle wheel was barely visible from the bottom of the boat. It had been pushed up through the hull. A piece of the thru hull fitting had been chipped and I could move the housing up and down. l pushed the rest of the housing down to where it should be and tightened up the thru hull fitting . It seems to be snug and back to normal but should I be concerned with a piece of the thru hull fitting chipped off at the top. It seems tight now and I couldnt move the housing up or down. Wouldnt the housing seal off any water coming in? I guess the only way to find out is to put it back in the water and see what happens. Any other ideas?
