While winterizing my 03 SANTE with the Excal 330 engine this weekend, I noticed that my heater supply and return lines are not connected in the same manner as what I have seen in other threads. One of the lines (don't know if it is the supply or the return) is connected as in the attached pic (thanks ag4ever for posting this in your heater install thread), but the other line is connected to the starboard side engine drain plug through a fitting.
First, is there a distinction at the heater core on what is a supply and what is a return? Also, I noticed that the heater didn't pump out any hot air this year. When I winterized the boat, I removed both heater hoses and, by mouth, blew air through the hose connected to the water pump. It was blocked, but after some effort I was able to blow all the water out and the hose now seems to be clear. Obviously the hose was blocked with something.
When I get the boat out in the Spring, should I route the hose currently connected to the block drain plug over to manifold, as in the attached pic. Sorry for the long-winded post. Just want to make sure I get this done right. Thanks.
