Let me start this by saying thanks to some of you that have embarked on this journey as I have read all the threads that are posted. I am not usually one to try and reinvent the wheel so I have taken from you and from how the factory installs the ballast systems in the new boats. The following is what I am installing:
Ski Locker - Gravity Games bag 19"x19"x88" or 1000lbs
Rear Side Compartments - 42"x16"x16" or 400lbs Each
Each bag will have its own pump, below the water thru hull to fill and empty, and a thru hull above the water line for a vent that has an inline back flow preventer. Below is the parts that I chose for each of those:
Pump - Jabsco Ballast Puppy with Switch
Below Water Thru Hull - Buck Algonquin Bronze Thru Hull, Ball Valve, and hose barb
Above Water Thru Hull - T-H Marine Brite Plate Chrome 3/4 90s
Back Flow Preventer - Whale inline 3/4 back flow
Fill and Empty Hose - 1" Wire Reinforced Engine Water Hose
Vent Hose - Shields 141 3/4 HD bilge Hose
If you are wondering why I used the 3/4 fittings on the vent, I did so because I am hoping that feeding with a 1" hose and venting with a 3/4 it will make the bag swell to a maximum size from a positive pressure on the feed side. I will have to get back to you on wether it works or not. If anything I saved some money because the 3/4 stuff is cheaper.
I have started the install and am to the point that I need to mount the pumps. I am waiting for a piece of aluminum from the sheet metal shop so I am stuck until I get that. I will have more pictures of the install later in the week. I will go ahead and attach pictures of what i have done so far. For the record the first hole was hard, but it got easier as I went.
