Clarion XMD3 with oval remote, bezel and JL Audio Bluetooth adapter
  • SilentSeven
    • Feb 2014
    • 2144
    • Bellevue WA
    • 2004 Nautique 206
    ACTIVE - Clarion XMD3 with oval remote, bezel and JL Audio Bluetooth adapter
    Working factory Clarion system pulled from my 2004 206. This an OE correct system as installed by Nautique in 2004. All parts working unless otherwise noted.
    This is a nice setup for anyone with an early 2000's Nautique who's current factory system is tired or not working. I think this system applies to years around 2002 to 2005.
    Here's what's included:
    1 / Clarion XMD3 headunit. In good working order. Cosmetically shows surface dirt and scratches consistent with years in the glovebox. Should clean up somewhat. Unknown if CD player works as I never used. See notes on missing items!
    2 / Factory sealing gasket. Matched gasket that goes with the Clarion headunit.
    3 / Snap on head unit side caps. These cover the mounting screws. Have a few surface scratches. No broken tabs.
    4 / Oval dash remote. All buttons and backlighting work. Has some light surface scratches that would polish out with plastic polish if motivated. Remote has factory mounting bracket.
    5/ Oval dash bezel for the remote. Item is in nice shape with correct stickers and no scuffs, fading etc. Includes factory mounting wing notes. Interestingly, this is a plastic part.
    6/ Aftermarket JL Audio bluetooth adapter. Plugs into the headunit AUX RCA ports and gives the unit bluetooth streaming function. Purchased from Crutchfield.
    What's NOT included:
    A / The clarion factory '16 pin' connecting harness. This is main plug in harness for power and non-RCA speaker connections. If your boat has the factory radio and no one has hacked the wiring, just plug your harness into the headunit. Otherwise, you can purchase both OEM and 3rd party versions of the harness on ebay for $15 to $20. Clarion has used this same harness connector for many unit's so it's not hard to find.
    B / The 6 pin headunit to dash remote extension cable. If going into a Nautique with a dash remote, you should have this cable pulled already. Otherwise you can order from ebay.
    C / you'll need to provide head unit mounting screws and back support strap.
    Price:
    $65 for all parts. Will not breakup. You pay shipping from Seattle area.
    Bellevue WA
