Transmission fluid leak
  • toddo75
    • Mar 2009
    • 48
    • Clermont, FL
    • 2015 G21
    Hello, I just purchased my first Nautique. A 2004 SAN. I was excited until I took it out for the maiden voyage. Loaded boat up with 2 families, wakeboards, wakeskates, wakesurfer, life jackets, food, etc. Ready for a day on the lake. I ran it for about 30 minutes and then noticed some oil coming out of the bilge. I opened the engine compartment and it was full of red tranny fluid. What the heck? I took it into Nautiques fo Orlando and they have to pull the tranny to see sup. It didnt sound good tho. Any one have any idea what may be happening?
    Thanks!
    Todd
    2004 Super Air Nautique
  • AuMDLST
    • Apr 2007
    • 870
    • Orlando, FL (Butler Chain)
    RE: Transmission fluid leak
    PM sent
    2006 SANTE 210 (Pending Sale)
    2005 206 TE (Previous)
    • jaybird
      • Oct 2008
      • 516
      • North Alabama Lake Weiss
      I believe you have the PCM 1:1 power plus transmission connected to the Walters V Drive. Your transmission may have gone out causing seals to fail. How many hours are on the engine? I have seen that drive arrangement fail as early as 250 hours. Just replace the trans and move on. **** happens! Bad shaft alignment can cause early failures, but the dealer should check that. I personally have no real history with the PCM 1:1 transmission however that is what my present boat has. I know the older Borg Warrner transmissions were good for well over 1000 hours when maintained properly. Maybe some of the other members have a better idea of the expected life of the PCM 1:1. That is something I would like to know.
      2012 Team Ski Nautique ZR409
      2011 Sport Nautique 200
      2008 SANT 230
      2003 Air Nautique 226
      1988 Martinique
      1979 Nautique
      1978 Tique
      1976 Tique (First New Boat)
      • toddo75
        • Mar 2009
        • 48
        • Clermont, FL
        • 2015 G21
        There are only 190 hours on the engine. We are hoping it just needs the seals replaced. Nautiques of Orlando are going to look at it this weekend.
        • jaybird
          • Oct 2008
          • 516
          OUCH! 190 hours........ let us know what they find.
          2008 SANT 230
          1988 Martinique
          1979 Nautique
          1978 Tique
          • ally606
            • Jul 2007
            • 66
            • Sunny Scotland.......
            the rear output seal failed on my '97 Sport (DD). It was a pretty simple job to pull the trans out, and fit a new seal. You may just have a pitted output shaft and a lip seal will take care of that. All in all, about 2-3 hrs work including realigning the engine.
            Loch Lomond: Scotland
            \'97 Sport Nautique, sacked and leaded out
            \'90 Mastercraft prostar with camo\' graphics
            • polkaking27
              • Jan 2005
              • 104
              Toddo,
              Any update on the transmission?
              if con is the opposite of pro, is congress the opposite of progress???
              • toddo75
                • Mar 2009
                • 48
                • Clermont, FL
                • 2015 G21
                No updates yet. Still waiting on Nautiques of Orlando to look at it. They have been swamped and said they need to pull out the V drive and tranny to see what is up. I am hoping to hear back from them today! I will keep you posted. Thanks
                • toddo75
                  • Mar 2009
                  • 48
                  • Clermont, FL
                  • 2015 G21
                  I got my 2004 SANTE back yesterday from Nautiques of Orlando and here is what happend: The rear main seal on the transmission was bad. They replaced the main seal, some o rings, pump cover and she is 100%, clean bill of health! The unfortunate thing is they had to pull the V drive and the tranny and pull the tranny to benchtest and it was 6 hours of labor. That is not cheap at all! Anyways, I guess it could have been a lot worse. I finally get to take the maiden voyage on her today! Cannot wait!
                  • polkaking27
                    • Jan 2005
                    • 104
                    toddo-
                    Glad to hear it was just some seals. Like you said it could have been worse... you could have been replacing the transmission. Anyway, let see some pics of the maiden voyage! Have fun, and good luck with no problems this time!
                    • 8122pbrainard
                      • Jul 2007
                      • 255
                      Glad to hear it wasn't the Walters! They have a tendency to self destruct and repairs can get into big $$$!!
