Announcement
No announcement yet.
G23 Prop Fell Off .....
  • #76
    I will be first to say that if they don't recall all of them they are a bunch of jerks. You are not the first guy this happened to that has done nothing wrong.
    To just fix the broken ones without a recall is unconscionable. It is too much unreasonable risk of being stranded in the middle of a lake, and potentially dangerous to the occupants if a storm comes up, and of course opens up to so much more damage if you then are stranded and are blown against rocks or what ever.
    How can you possibly be out there in a g23 or g25 with what you paid and have piece of mind? Maybe they can get away with a special shaft that is a larger diameter in last 6 inches or so.
    • #77
      Why is everyone raising a fuss about there not being a service bulletin from Nautique for this? If I remember correctly, there is, indeed, one. The original poster asked his dealer if it applied to his boat, but the dealer said it did not. Maybe it's possible that the dealer just didn't do good enough research on it before saying that it didn't apply to his boat.
      2018 SAN G23 XR550
      2015 SAN G23 XR550
      2014 SAN G23 XR550
      2013 SAN G23 XS550
      2013 SAN G23 ZR450
      2011 SAN 230
      2010 SAN 230
      2000 XStar
      www.mnspringride.com
      • #78
        ^^^ upgraded 1.25" shafts on all 2014s+. 4... lets say an even 10 failed propshafts on nearly 900 2013 Gs.
        For 2014:
        -550 motor is 1 1/8 shaft with 15" prop
        -450 motor is 1 1/4 shaft with 17" prop
        2014 G23 450 Coastal Edition
        2013 G23 450 Coastal Edition
        2010 SANTE 230
        2007 SANTE 220
        2003 SANTE 210
        • #79
          Actually Ryan is right, I was misinformed. They are all 1.25" on the 2014
          Originally posted by nauty220 View Post
          For 2014:
          2010 SANTE 230
          2007 SANTE 220
          2003 SANTE 210
          • #80
            Correct, Acme 2261 is the OEM prop on 2014 550s, its the 1.25" version of the 2247.
            2019 G23 450
            2014 G23 550
            2013 G23 450
            2011 Malibu Wakesetter 247
            2007 Yamaha AR210
            • #81
              I got a response today from nautique saying they will be replacing the shaft with the 1.25" one as well as the prop. I would assume it will be the Acme 2261. Do you know if this prop handles exactly the same as the 2247? I really liked the performance of the 2247 and don't really want the boat to deviate from that.
              • #82
                ^^ Exact same prop, just a bigger hole for the 1.25" shaft.
                2019 G23 450
                2014 G23 550
                2013 G23 450
                2007 Yamaha AR210
                • #83
                  I thought I read somewhere that the prop shaft will be 1.25 but will still be tapered to fit the standard props that go on now?
                  • #84
                    Good to know that Correct Craft is taking care of you. Make sure it is new NEW spec shaft they are installing.
                    Still such a bummer to experience being stranded. Here's to moving on and safe boating.
                    All the Best!
                    Boat - 2005 Team 226 -ZR6 - Several Acme Prop's (1234, 644, 1160) Depending on occassion
                    Tow Rig - 2008 Chevy Silverado - Duramax Diesel - Crew Cab
                    • #85
                      No, that is not correct. All 2014 G series boats will have different props than 2013 boats, even the 550 boats.
                      Sent from my iPad using Tapatalk HD
                      Current Boats —> 2024 Super Air Nautique G23 PARAGON -- 2018 SAN 210 TE -- 2003 Ski Nautique 196 -- 2002 Ski Nautique -- 2001 Ski Nautique -- 2000 Sport Nautique -- 2000 Nautique Super Sport -- 1998 Ski Nautique -- 1996 Ski Nautique Open Bow -- 1985 Sea Nautique 2700 (Twin-Engine, 1 of 13) -- 1981 Fish Nautique (Twin-Engine, 1 of 4) -- 1980 Fish Nautique (Twin-Engine, 1 of 4)
                      Former Boats —> 2023 Super Air Nautique G23 --
                      2022 Super Air Nautique G23 PARAGON -- 2021 Super Air Nautique G23 -- 2021 Super Air Nautique G23 -- 2020 Super Air Nautique G23 -- 2019 Super Air Nautique G23 -- 2018 Super Air Nautique G23 -- 2017 Super Air Nautique G23 -- 2016 Super Air Nautique G23 -- 2015 Super Air Nautique G23 -- 2014 Super Air Nautique G23 -- 2014 Super Air Nautique 230 Team Edition2013 Super Air Nautique G232012 Super Air Nautique 210 Team Edition2011 Super Air Nautique 210 Team Edition2010 Super Air Nautique 210 Team Edition2008 Super Air Nautique 230 Team Edition2007 Air Nautique 236 Team Edition -- 2007 Air Nautique SV-211 -- 2005 SV-211 -- 2003 Super Air Nautique 210 Team Edition -- 2003 Air Nautique 226 -- 2003 Sport Nautique 216 -- 2003 Ski Nautique 196-- 2001 Sport Nautique -- 2001 Ski Nautique --1999 Ski Nautique Open Bow -- 1999 Air Tique 176 -- 1998 Ski Nautique -- 1998 Ski Nautique -- 1997 Ski Nautique -- 1997 Ski Nautique -- 1994 Ski Nautique -- 1993 Barefoot Nautique -- 1983 Fish Nautique (TWIN ENGINE, 1 of 4) -- 1981 Fish Nautique (SINGLE ENGINE)
                      NautiqueParts.com - Roswell Marine - Phoenix Trailers - SkiSafe - PCM Marine Engines - PerfectPass - C&S Marine - OJ Propellers - WakeMakers -- Swell Wakesurf
                      • #86
                        Originally posted by AirTool View Post
                        Its not torque that shears the shaft. It is a combination of torque and bending cycles because the shaft is spinning and the prop is cantilevered past the last bearing. This fatigue can be exaggerated if a shaft is not properly aligned.
                        Stress over time is called "fatigue" and is the single biggest cause of catastrophic design failures.
                        Clearly....the prop diameter/load is way too much for the shaft diameter. Isn't this the same shaft size as my 330 direct drive?
                        I'd suggest (although not calculated) the shaft diameter (or maybe area) should go up proportional to engine horsepower.
                        Partially correct, partially incorrect. It is in fact torque that will twist the shaft to the point of shearing as shown in the picture. The torque of the motor multiplied by the reduction of the trans/v-drive is one side of it, the size of the prop resisting that torque is the other. Prop sizes tend to get larger as cubic inches increase. Supercharging has the same effect as adding cubes.
                        Small block boats with the 1.23 and 1" shafts along with their common ~13x16 prop sizes are at the upper end of the acceptable strength limit of normal driveshafts. Mastercrafts from the 80's with small blocks and Powerslot (1.5:1) transmissions ran 1-1/8". Same goes for all of the v-drive CC's that end up with a 1.5:1 reduction... 1-1/8" shafts for those small block boats (90's through current) as well. Correct Craft deemed the Python powered (496-502ci big block) direct drive boats with 1.23 transmissions to require 1-1/8" shafts too.
                        Greg Meloon's comment about going to 1.25" shafts was as a direct result of the 2:1 reduction transmission coming for 2014- not necessarily an admission that the 1-1/8" were insufficient on 2013 boats that had 1.5:1 reductions. That being said, I have seen some boats push the normal envelope and start breaking shafts... my buddy has a 500hp 408w in front of a 1.23 and he has twisted off several 1" shafts just like this G. The 550SC motor with a 1.5:1 reduction seems to be pushing the limits of a 1-1/8" shaft in a similar fashion.
                        Good on CC for fixing this issue. Its not a cheap upgrade- prop, shaft, strut and packing gland (presumably dripless) will all have to change to the larger diameter.
                        1990 Ski Nautique
                        NWCT
                        • #87
                          Great news!
                          • #88
                            I read this, however I didn't laugh or find it funny. This is a major flaw and should be fixed on all G series boats.
                            However I'm glad to see CC is taking care of you. I didn't expect anything different.
                            • #89
                              My discussion with Nautique, and it was reinterated several times by different people in response to questions I asked at the factory is that it was an issue with a suppliers batch of prop shafts primarily during the first of the Gs off of the production line, and the bulletin was sent out to dealers who sold those boats. When they found out about the issue with the shaft/supplier they replaced each when the dealer contacted them after referencing the recall notice sent to them. I am not sure it was a design flaw near as much as a supplier quality control issue, which ultimately Nautique is responsible for. Since the majority of these catastrophic failures occurred in the early boats, and OP was not the original buyer of the boat, I would say that Nautique is doing exactly what they are supposed to do, which is support their product and warranty. With a bad batch of shafts, the diameter likely would not matter, therefore, replacing each shaft after the problem was identified and rectified makes little sense. That being said, I would love a larger diameter shaft which could handle a 17" prop on my 550, but early failures which are being handled well through the warranty process are not a reason to call for the replacement of every shaft on the water. Just my opinion. I am glad that the OP had no problem getting this taken care of through Nautique. Just like the warranty is designed to do.
                              Eric, Phoenix AZ
                              G23 550 hp (finally here)
                              2002 Super Air
                              • #90
                                reiterated not reinterated, typed too quickly
                                Eric, Phoenix AZ
                                2002 Super Air
