Page 4 of 12 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 116
Thread: 1997 Super Sport - Red/Black AIR - Work in Progress ---Lots of Photos
  1. #31
    Aug 2013
    Montreal
    Beautiful ride!!!! Is that an old Obrien wakeboard in the front storage area? I have that one mounted on my wall as it was my first board. Can you surf with that board? How do you plan on setting up the ballasts? I am looking at a really clean 1995 Super Sport and trying to figure out the best way to set up a ballast system. Secondly, do you know a good place to order decals?
  2. #32
    Jun 2013
    Central Illinois
    430
    New stuff!
    Got a new headunit that let's you put your iPhone or iPod INSIDE the headunit. Also got a transom remote for it. Had to drill a 3.25" hole in the transom. That was fun with a Dremel tool!
    I also got my sub in and installed my amp. The sub is a DVC alpine type S. I wired it in parallel to drop the impedance down to 2 ohms. The amp is a polk 5000.5.
  3. #33
    Jun 2013
    Central Illinois
    430
    More pics of amp install
    I then mounted my fuse block for my upcoming ballast install. Gonna have 6 aerator pumps wired to it.
  4. #34
    Jun 2013
    Central Illinois
    430
    Quote Originally Posted by Wakerider90 View Post
    Ya it's an old obrien. We tried surfing with it but it isn't buoyant enough. Ballast bags are two 750s in engine compartment and the flyhigh locker/backseat bag in locker that's a 580 bag. Ill have 300 in lead/iron weights in the bow. Go to www.nautiqueparts.com for decals.
    I'm doing an aerator pump system for ballast instead of reversible pumps for these reasons.
    1. Cost
    2. Speed
    3. Ability to run dry
    4. I like watching water drain out the side.
    5. Less amp draw, I gots 1 battery.
  5. #35
    Jun 2013
    Central Illinois
    430
    Teaser for my weekend project.
  6. #36
    Jun 2013
    Central Illinois
    430
    Started prepping for tomorrow's delivery
  7. #37
    Jun 2013
    Central Illinois
    430
    Started my ballast project last night and finished it a few hours ago.
    Here's what happened.
    All this stuff came in from wakemakers. Those guys are awesome.
    I was originally going to make a manifold out of 3/4" T fittings but when I saw them I changed my mind
    So I went to the store and made a manifold out of 1 1/4" PVC. Which is e same size as my one and only thru hull
    What I originally had in my head and what actually would work
    More to follow.
  8. #38
    Jun 2013
    Central Illinois
    430
    Big hole in the bottom of my boat
    Picture of the mushroom thru hull
    With the street elbow and ball valve
    Started plumbing hoses. I use a t1200 tsunami pump for fill and a 1" hose. Use t800 for drain and 3/4" hose. I used Y fittings to connect my drain and vent lines. Check valve on vent line.
    Pic of pumps
  9. #39
    Jun 2013
    Central Illinois
    430
    Running hoses across gas tank to the rear of the boat
    Hoses on pumps. Heat gun>hair dryer.
    Template for vents/drains. Order from left to right or back to front goes left bag, right bag, locker(front ) bag
    Traced area for switches
    Some bags with hoses
  10. #40
    Jun 2013
    Central Illinois
    430
    Switch housing installed
    Wiring the switches. Wires go from pumps to switch. Then switches are powered through the fuse block I installed earlier.
    Replaced the fuel tank cover
    Pics of vdrive storage with dividers and all hoses/wires ran
