Originally posted by shag
View Post
Originally posted by sodbuster88 View PostI like the word. Should send that into Webster.
The example closest to home is the coiled plate that is dropped in the fire tube of a household gas fired water heater. It turbulates the laminar flow into turbulent flow to increase the heat transfer coefficient.
My first experience with turbulators were in some air cooled heat exchangers for a gas plant in Saudi...in the early 90's....long story.
There are also other forms/uses.
If you study some fish...generally the football shaped ones, many have a lateral ridge on their forehead to turbulate the flow as it passes over them. For large surface area bodies, generally turbulent flow has less drag than laminar flow and the ridge forces turbulent flow even at low speeds. IIRC, this feature is called "tripping" and is usually included on engineered low drag vehicles like the flat bellied, teardrop shaped solar cars. Maybe google boundary layer tripping.
Back to the engineered fish, it is still hard for me to understand how some believe everything evolved from the same fleck of dust.
Great info! PCM sent me one, as well. To those that have installed the "whistle plate" (spacer) from PCM on a 343, does it replace the existing gasket between the throttle body and upper intake? Or does it go in along with the gasket but either below or above it? This seems pretty easy to install even for me (not the most mechanically inclined). Anything else I should be aware of on the install? Thanks!!
