Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: 2003 SANTE battery compartment enlarging
    Feb 2004
    Huntsville, AL
    590
    Cool 2003 SANTE battery compartment enlarging
    So against everyone's better judgement I went ahead and started my battery compartment enlargement project in my 2003 SANTE. A little background, this is to install 2 batteries in the port side compartment for stereo power and enlarge the starboard side so a Group 27 will fit for the house side. I made the port side large enough to fit Group 27's as well. After making some careful measurements before and after I removed the carpet all that was left to do was start cutting.
    PSA - For those of you that are squeamish turn away now!!! What you are about to see my disturb you...
    Measuring and taping off cut lines...
    First cuts... I used a Ridgid "Jobmax" to make the cuts with. It did a great job but goes through batteries every 30 minutes so 2 are a must! I tried a jigsaw at one point but this fiberglass ate through blades like crazy. 6" of cutting and the blades was useless.
    First few pieces removed... I used a hacksaw blade to cut the foam by hand, but later mover to a drywall saw...
    All the sides gone on the starboard box...
    All the foam removed on the starboard battery box. I wasn't originally going to remove all the foam to the hull, but I ran into some moist foam at the very bottom and wanted to investigate more. Never figured out where the moisture came from, but the further back toward aft I went the more I found.
    Now to start on the port side...
    I ran into a surprise on the port side that gave me a bit of a scare, but I was too far gone to stop now. A lock washer made its way into the laminating process somehow and just happened to be right in the middle of one of my cuts. My heart sank a little when I heard the multi-tool change pitch at first.
    All the fiberglass and foam now gone on the port side as well... The tube is a piece of PVC that goes through the stringer into the bilge to allow water to drain. I will cut it back during the laminate process.
    At this pint all the cutting was done, foam removed, and I took a step back to see what I had accomplished. That's when the feeling that a person gets in any project hit me... "What have I done?!?!"
    More pics to come as the laminating process begins... Time to ring in the New Year and have a drink... or a dozen!
    Jason
    All black 2003 SANTE
    www.wakefactory.net
    -- Southern Fried --
    Jun 2009
    Cedar Creek Lake TEXAS
    737
    Looks good, see you havent got that trans valve on yet. Did you get it?
    Feb 2004
    Huntsville, AL
    590
    Yeah I got it, just haven't gotten around to putting it on yet. Thanks again...
    Jason
    www.wakefactory.net
    Dec 2007
    Lakewood, WA
    161
    Great job Jason! I'm impressed with your courage and workmanship. I also tackle things such as this and know the feeling well of that first hole/cut and whether or not it will end up as an "OH SH*T" moment! Once you cross that point of no return you can only proceed slowly and with confidence. When things go well, the satisfaction is well worth the risk. Thanks for sharing the pics in such detail as this will no doubt help others have the confidence to take on like projects.
    Ron
    2004 196 LE Black/Grey
    330HP Excalibur Water Churner
    2002 Grey F150 Harley
    475+HP Supercharged Tire Burner
    Feb 2008
    Indianapolis, IN
    44
    Jason,
    Great work and I can't wait to see the finished project.
    Mark @ N3
    May 2011
    Minneapolis, MN
    107
    Really looking forward to how you finish this up. Its a great start so far. I have an 03 SAN and this is on my winter list as well.
    Thanks!
    Mar 2009
    Kingsland TX
    270
    5
    How's this going? It's got me thinking up all kind of things to do.
    Feb 2004
    Huntsville, AL
    590
    Unfortunately not much progress has been made because my schedule has been too full. I did get new foam sprayed in place though. I just need to trim it down a bit and then I can start with fiberglass layup.
    Jason
    www.wakefactory.net
    Aug 2009
    Frisco, TX
    88
    Jason, I just finally caught this (I've been slacking on my PN attendance lately). It looks great. I wish our SAN had dual battery boxes in it like yours did originally. We only had one on the port side. Just goes to show that CC didn't have a standard for them coming out of the factory. Anyway, keep up the great work and post up the progress. As long as you do a good job with the lay-up, you'll really enjoy the extra space for the batteries. Nice job...
    Feb 2004
    Huntsville, AL
    590
    Been busy the past few weeks and haven't gotten much accomplished. I did get some new foam sprayed in and trimmed it back down to the dimensions I need. Now I need to fill just a few voids in the foam and start cutting the fiber mat to get ready for lay-up. Few more progress pics...
    Jason
    www.wakefactory.net
